Old 09-26-2009, 09:15   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 550
sigmatel s98 "Not Calibrated" error
hi
sigmatel s98 "Not Calibrated" error .....................please help
Old 09-26-2009, 10:21   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,298
Originally Posted by zeerik View Post
hi
Hello,
Could you, please, make more detailed explanation of this problem.
When you see this error ?
What you have tried to do with phone already ?
What was the results ?
please be as detailed as possible, including LOGs
Old 09-26-2009, 13:10   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 550
first i format (safe) .................then flash it but same
COM8 [VCP0] selected
module v2.91
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M_2.bi n
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1C03:0002
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
rom info protocol ver: 04
ver. sw 1: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN
ver. sw 2: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__ffs...
file saved: E:\InfinityBox\ChineseMiracle\T600_V04_PCB01_GPRS_ MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ffs_2 0090927-044354.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
startup code area #1 check...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
Finalization ...
Finalization Done
Finished, time used: 652 sec
Remove/Install battery now !
Old 09-26-2009, 16:13   #4 (permalink)
Member: 130995
Hello,
What is "same" ?
Please, explain what is "not calibrated" problem means.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-26-2009, 17:16   #5 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 550
Originally Posted by InfinitySupport View Post
Hello,
What is "same" ?
when power on there written "NOT CALIBRATED" set remains this mode not go to menu
Old 09-27-2009, 15:03   #6 (permalink)
Member: 148515
Thanks Meter: 15,062
hello!
is it touchscreen calibration mode?
Old 09-27-2009, 16:08   #7 (permalink)
Member: 185776
Thanks Meter: 73
No sir,Actually for this problem same model set (SIGMATEL S98 WITH GOOD WORKING CONDITION) READ FULL FLASH AND WRITE TO COMPLAINT SET,RESULT IS 1000% OK.
Old 09-27-2009, 21:42   #8 (permalink)
Member: 148515
hello!
do you have such flash file? i would upload it to support
Old 09-28-2009, 14:44   #9 (permalink)
Member: 185776
Thanks Meter: 73
sure sir,I will upload to support sir.
Old 09-28-2009, 22:15   #10 (permalink)
Member: 148515
hello!
upload it to www.rapidshare.com and post here link.
thank you in advance!
Sigmatel s98 "Not Clibrated" solved 100% zeerik Infinity-Box 14 05-15-2011 11:28
Tested Solution for Sigmatel "Not Calibrated"- PASSIONATE_BOYS Infinity-Box 22 04-03-2010 13:05
I need Sigmatel S98 help me Tamansu Chinese Models & Cloned Phones 4 08-12-2009 17:54
sigmatel s98 dead after code *#33646633# dakku Chinese Models & Cloned Phones 0 03-07-2009 16:42
Page generated in 0.36768 seconds with 8 queries
