Old 09-27-2009, 09:35   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
Sigmatel s98 "Not Clibrated" solved 100%
only flash with attached eeprom file..............done
COM8 [VCP0] selected
module v2.91
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
skip: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88.B0E.bin
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:1C03:0002
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device rom info...
detection phase #1...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
rom info protocol ver: 04
ver. sw 1: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN
ver. sw 2: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detect device sec info...
detect device sec info finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__ffs...
file saved: E:\InfinityBox\ChineseMiracle\T600_V04_PCB01_GPRS_ MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ffs_2 0090928-022338.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
Finished, time used: 263 sec
Remove/Install battery now !
The Following 6 Users Say Thank You to zeerik For This Useful Post:
Old 09-27-2009, 14:24   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
was it "tochscreen" not calibrated?
did you try to solve it by "bypass touchscreen calibration" ?
Old 09-28-2009, 14:21   #3 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
hello!
it is not tuch screen calibration problem ........first of all i tried clibration tuch screen option (all mode) ..............but not fixed........then problem solved flashing with eeprom file
Old 09-28-2009, 21:21   #4 (permalink)
Member: 148515
hello!
i will add this file to support with a name
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88_eeprom_for_not_calibrated.B0E.bin
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 09-29-2009, 14:44   #5 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 327
yes for me working 100000000000000% perfect sloution
thank you very much MR.
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post:
Old 10-04-2009, 14:52   #6 (permalink)
Member: 360614
Thanks Meter: 63
How to write this eeprom file with spiderman box? I got error while flashing eeprom. please help?
Old 10-04-2009, 15:59   #7 (permalink)
Member: 882459
Sonork: EngrRML
Thanks Meter: 9
Not possible when using spiderman. This eeprom can only be used in Infinity.
Old 10-05-2009, 07:44   #8 (permalink)
Member: 360614
Thanks Meter: 63
Any possible idea with spiderman, cause I don't have infinity. Or can u give me a link of flash file of sigmatel S98
MTK_ROMINFO_v04T600_V05_PCB01_GPRS_MT6226_S01.T600 _V05_ENFRARRUSPPEVI_SIGMATEL.BIN
The Following 2 Users Say Thank You to Achyut For This Useful Post:
Old 02-26-2010, 11:18   #9 (permalink)
Member: 392151
Thanks Meter: 80
hey u r gr8 man tested eeprom file ...........100% working f ine
The Following User Says Thank You to jitugrover For This Useful Post:
Old 11-15-2010, 08:40   #10 (permalink)
Member: 1047695
Sonork: none
i need a flash file sigmatel s98 plz send me thankx in advance
[email protected]
Old 11-15-2010, 21:56   #11 (permalink)
Member: 148515
[email protected]
hello!
which is required software version?
do you have infinity box?
Old 03-08-2011, 09:49   #12 (permalink)
Member: 1304552
Thanks Meter: 20
i need eprom for s98
the attached eprom is not working
plz give eprom for the given firmware -
T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S98_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M
Old 03-12-2011, 21:07   #13 (permalink)
Member: 148515
hello!
what problem you have with your phone?
did you try to make format FFS?
this rebuild EEPROm to factory state
Old 05-15-2011, 07:33   #14 (permalink)
Member: 878884
Thanks Meter: 3
hey dear i also need this file of sigmatel s98 eeprom
Old 05-15-2011, 10:28   #15 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
What is the problem with phone?
Most of the problem can be solved by format ffs/repair imei.
Wr.
sigmatel s98 shihabps Chinese Models & Cloned Phones 8 10-05-2009 09:48
sigmatel s98 "Not Calibrated" error zeerik Infinity-Box 9 09-28-2009 21:15
I need Sigmatel S98 help me Tamansu Chinese Models & Cloned Phones 4 08-12-2009 16:54
sigmatel s98 dead after code *#33646633# dakku Chinese Models & Cloned Phones 0 03-07-2009 16:42
Page generated in 0.24841 seconds with 10 queries
