02-12-2009, 10:56 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Lg kp100 were not unlocked COM5 [VCP0] selected module v1.62 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090212-152116.B1E.bin loading data... data loaded imei: 35588202440771200 reading eeprom-security_35588202440771200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202440771200_20090212-152117.B1E.bin reading eeprom-complete_35588202440771200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202440771200_20090212-152119.B1E.bin backup critical area Done Check memory ... loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... error: source buffer too small: 00000011 instead of 000001DA error: operation terminated [00FF] loading data... data loaded code: 16743544 error: not locked or unknown eeprom Check memory Failed Finished, time used: 12 sec Remove/Install battery now ! Ifinity team please tell me whats a error ????? |
02-12-2009, 11:19 | #2 (permalink) |
Insane Poster Join Date: May 2008 Location: india
Member: 765452 Status: Offline Thanks Meter: 25 | Here is mine also COM5 [VCP0] selected module v1.62 Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090212-154817.B1E.bin loading data... data loaded imei: 35588202440876900 reading eeprom-security_35588202440876900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202440876900_20090212-154817.B1E.bin reading eeprom-complete_35588202440876900... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202440876900_20090212-154819.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 77723319 Finished, time used: 11 sec Remove/Install battery now ! |
02-12-2009, 11:27 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | BRO U CAN CHECK THIS LINK I HAVE SUCESSFULLY UNLOCKED THIS VERSION OF KP100 THANKS INFINITY TEAM FOR THE FAST FESPONCE FOR THIS PHONE http://forum.gsmhosting.com/vbb/showthread.php?t=677676 WBR sahil2000ind |
The Following 3 Users Say Thank You to sahil2000ind For This Useful Post: |
02-13-2009, 08:44 | #4 (permalink) | |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Quote:
02-13-2009, 09:07 | #5 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 852575 Status: Offline Thanks Meter: 11 | please do use pana1.61 or 1.62(aguale). download firmware from support and flash. its now unlocked .....enjoy. infinity team has told before that there is some bug in new pana 1.62. no problem always there is solution you work hard and try and try. i hope infinity will remove this bug very soon. |
02-13-2009, 17:22 | #6 (permalink) | |
Member: 765452 Status: Offline Thanks Meter: 25 | Quote:
02-13-2009, 17:46 | #7 (permalink) |
Member: 765452 Status: Offline Thanks Meter: 25 | Yes unlock sucessfull by sahil2000ind method COM5 [VCP1] selected module v1.61 Device: LG-KP100 Checking data, wait... Action: unlock read unlock codes Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 230400 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .01 ULC2GL 2008-03-06 1.0 TMO_CZ KP100 00 420 V10a 230-01 MA Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090213-221118.B1E.bin loading data... data loaded imei: 35588202440771200 reading eeprom-security_35588202440771200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202440771200_20090213-221119.B1E.bin reading eeprom-complete_35588202440771200... file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202440771200_20090213-221122.B1E.bin backup critical area Done Check memory ... loading data... data loaded code: 16743544 Finished, time used: 15 sec Remove/Install battery now ! Thanks to sahil2000ind your method works.Unlock sucessful.............. |
The Following User Says Thank You to khanrizwan For This Useful Post: |
02-13-2009, 21:57 | #8 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 914747 Status: Offline Thanks Meter: 22 | infinity box always reading code on this model look @ d end there is a unlocking code in 8 digit put an non accepted sim card nd press unlock nd put your code read by infinity box keep it up thanks i done more then 150 pcs never error in any single 1 if u unlock an unlocked fone then it gives error error reading data r fone is not locked i got backup of all of them br |
02-14-2009, 08:26 | #9 (permalink) |
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | @AY29!4LYF RELIANCE (smart mbile services india) HAS CHANGED THEIR SECURITY VERSION sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0 THIS VERSION PROBABLY IS STILL NOT POSSIBLE TO UNLOCK BY DIRECT UNLOCK METHOD SO WE HAVE TO FLASH IT WITH OTHER FIRMWARE I HAVE TESTED IT ON MORE THAT 200 MOBILES SETS WITHOUT ANY PROBLEM @Infinitysupport WE ALL MEMBERS ALSO WAITING FOR THE DIRECT UNLOCK METHOD FOR THIS VERSION AS IT TOO TIME TAKING TO FLASH ALL THE SETS TO UNLOCK WBR sahil2000ind |
The Following User Says Thank You to sahil2000ind For This Useful Post: |
10-27-2009, 08:24 | #10 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 229056 Status: Offline Thanks Meter: 95 | module v1.70 Device: LG-KP100 Checking data, wait... Action: unlock direct unlock method #1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... slowest Set Baud Done Connecting ... Connecting Failed Finished, time used: 7 sec Remove/Install battery now ! pleas help me i sett all baud rat |
Lg kp100 problem with unlock [Closed] | iliya _angelov | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 16 | 05-07-2012 12:05 |
Lg KP100 reliance gsm unlock successfull | abhishek aga | ET-BoX | 15 | 10-02-2011 17:23 |
LG Kp100...can not enter unlock code? :::SOLVED::: | husainm | PolarBox 3 | 2 | 02-19-2009 22:41 |
lg kp100 orange spain unlock problem SOLVED | sunnagar | PolarBox 3 | 2 | 09-20-2008 19:42 |
LG Kp100 fail to unlock. | rotelcam | Infinity-Box | 3 | 08-17-2008 15:50 |
