Old 06-11-2009, 07:01   #1 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
sigmatel shows only not calibrate
sigmatel s88 shows only not calibrate on screen please help
The Following User Says Thank You to rakesh15 For This Useful Post:
Old 06-11-2009, 08:18   #2 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
Thanks Meter: 473
which version of chinese miracle u r using???
The Following User Says Thank You to azeem781986 For This Useful Post:
Old 08-02-2009, 06:50   #3 (permalink)
Member: 43383
Thanks Meter: 18
i have the same problem
after safe format set says not calibrates
please give some solution infinity team
best regard
abhishek
The Following User Says Thank You to abhi1 For This Useful Post:
Old 08-02-2009, 07:45   #4 (permalink)
sharmin's Avatar
Member: 222009
Sonork: 100.1576751
Thanks Meter: 435
yes same to me with sigmatell S3
not calibretting
The Following User Says Thank You to sharmin For This Useful Post:
Old 08-02-2009, 18:01   #5 (permalink)
rehmani's Avatar
Member: 333199
Sonork: may i help u just pm me
Thanks Meter: 2,405
not calibretting
yes i agree wid u infinity latest version not calibrate touch screen but old version working fine
Old 08-02-2009, 21:37   #6 (permalink)
Member: 130995
Thanks Meter: 35,227
How to calibrate touchscreen:
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. make full flash backup for emergency case
8. go to software "Service" page
9. select calibration "mode-1"
10. make "Reverse calibration order" un-checked
11. press "Calibrate touchscrren" button and follow instruction given by software
12. if software can not make calibration with "detection failed" error:
- select other calibration mode (f.e. "mode-2", "mode-3" etc. one by one)
- repeat calibration process
- test phone after each "mode" try
13. if calibration process finished without errors but touchscreen can not work well:
- DO NOT change calibration "mode" !
- make "Reverse calibration order" option checked
- repeat calibration process again
- test phone
14. if still no luck with calibration after all tries:
- make full flash backup for emergency case
- make "format ffs"
- Power-On phone
- Power-Off phone by "Power" button (do NOT remove battery)
- Repeat "Calibration" operation again
- if still no luck read full flash and send to support with subject: touchscreen calibration failed
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 08-03-2009, 09:57   #7 (permalink)
rehmani's Avatar
Member: 333199
Thanks Meter: 2,405
- test phone
- make "format ffs"
- Power-On phone
but dear when i use version 2.77 it calibrate my sigmatel s3 touch screen so i am sure there is bug in latest version .
4 days before i lost my whole computer data so i have now no cm setup v 2.77 plz sir can u provide me that version setup.
thanx in advance
The Following User Says Thank You to rehmani For This Useful Post:
Old 08-04-2009, 05:58   #8 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
i have sigmatel s98 its only show not calibrated
this is not tech screen problem tech screen is ok
i do complete format and try to repair tech screen calibrated but its not working phone power on but not connected
COM4 [VCP0] selected
module v2.87
Action: touchscreen calibration
mode: 1
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:6403:0000
status: FF
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 60 sec
Remove/Install battery now !
i try all mod but same and last i flash the phone same fimware download from support area but same........not calibrated show on the screen.
How soveled this problem??????
Guljee
The Following User Says Thank You to guljee786 For This Useful Post:
Old 08-04-2009, 07:00   #9 (permalink)
Member: 43383
Thanks Meter: 18
i have flashed the phone with firmware on support but problem is same its not its not calibrating but its the same problem like bad software its the phone says not calibrated
Old 08-04-2009, 10:19   #10 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
yes same problem like bade software.............................
Guljee
Old 08-04-2009, 14:40   #11 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
any solution ??????????????????
Guljee
Old 08-04-2009, 22:45   #12 (permalink)
Member: 148515
Thanks Meter: 19,534
hello guys!
what happends if you try to calibrate screen manualy, by touching test points with a pen?
Old 08-05-2009, 14:01   #13 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
no working tech screen in this error. before formatting teach screen work fine...........and its not show teach screen calibrated
its show only not calibrated on screen.
Guljee
Old 08-06-2009, 23:21   #14 (permalink)
Member: 130995
Hello,
Touchscreen calibration procedure changed, ChineseMiracle v2.88 released: http://forum.gsmhosting.com/vbb/showthread.php?t=801258
Please, try to calibrate phone with new software, waiting for your results.
Old 08-08-2009, 10:46   #15 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
Touchscreen calibration not working this error (not calibrated) this problem same as (bad software)
module v2.87
- for this operation you need to have full flash backup from phone
- if you have full flash backup already press "Yes", select full flash file and follow instructions given by software
- if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure
Do you have full flash backup ?
Loading file v.04...
T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M.bin loaded
detected record size adjusted
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Finished, time used: 80 sec
.Gulljee
sigmatel S88 shows NOT CALIBRATED k_abhi Infinity-Box 27 12-13-2011 11:17
Sigmatel s88 not calibrated solution tajinder Infinity-Box 8 06-27-2010 21:02
Nokia 1255 show only bettery . sonu arya Nokia CDMA 8 05-07-2010 18:47
sigmatel s88 shows only not calibrate rakesh15 Infinity-Box 0 06-11-2009 06:51
Show not calibrated on screen youarethebest Infinity-Box 6 05-10-2009 23:56
Page generated in 0.21024 seconds with 10 queries
