08-19-2009, 08:56 | #1 (permalink) |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | <<< Sigmatel T white LCD problem >>> module v2.89 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:ED03:000F status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation ==================== New firmware detected (v.2.89, database date: 10.08.2009): M628BASE_A_XSKJ_L42_PCB01_GPRS_MT6225_S00.M628-XSKJ-ST-L42-090319.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: M628BASE_A_XSKJ_L42_PCB01_GPRS_MT6225_S00.M628-XSKJ-ST-L42-090319.BIN ver. sw 2: M628-XSKJ-ST-L42-090319, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 2088C4FFFFFFFF:2088C400000000 Finalization Done Finished, time used: 494 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
08-19-2009, 18:45 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sad that you disabled auto-backup of eeprom area sigmatel phones very often goes to White LCD after format. that is why i always advice to make full backup, especially if program says that !!!"- make "Read full flash" operation"!!! now only same version working phone can help read backup from working phone and write to fault one |
<<< Lg Kg 195 Restart Problem >>> | Faisal_Computer | VygisToolbox | 4 | 12-14-2009 11:46 |
<<< Sigmatel T55 white LCD problem >>> | Shakeel_pattoki | Chinese Models & Cloned Phones | 1 | 08-19-2009 09:48 |
<<< Samsung c120 autocall answer problem >>> | khadim100 | UST Pro II | 2 | 11-15-2008 08:12 |
<<< Lg Kg 195 Restart Problem >>> | Faisal_Computer | Infinity-Box | 5 | 07-21-2008 16:14 |
