08-07-2008, 05:59 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Simco Sm 633 Set Dead After Flash Device: Simoco-SM633 Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:AC03:0002 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 98004900000002:FFFFFF00000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... .................................................. .............. warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\eeprom_20080807-100926.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 98004900000002:FFFFFF00000000 Write: Firmware Area: Eeprom/ffs flash: 98004900000002:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 991 sec Remove/Install battery now ! NEED HELP .............FLASHED FROM SUPPORTAREA.......FALSHED THE BACK UP BUT STILL SET DEAD.........SET WAS OK PREVIOUSLY EXCEPT RESATRTING AFTER FORMAT SAFE FFS SET GONE DEAD ..THEN I FLASHED AS ABOVE |
08-07-2008, 14:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If you flashed phone with original backup and phone can not be returned to it\'s original state this means that your phone has some kind of hardware problem ! You must repair phone hardware, f.e. reball CPU and flash chip |
08-07-2008, 16:07 | #3 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Hard ware part complete, Flashing ok..but not connecting FFS....error model not entering test mode......what may be wrong???? |
08-08-2008, 10:28 | #5 (permalink) |
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | sir set is full flashing..but when ....i am connecting FFS for format set not entering test mode for formating.........connection fail try again...this is th error, where as full flashing without error and connecting as in my first post |
08-11-2008, 14:49 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to flash phone again with files from support area. If problem still exist you need to open phone and check it\'s hardware, f.e. reball flash IC |
1600 set dead after flashing also set not power on..... | dhineshh | Nokia Hardware & Hardware Repair | 1 | 05-09-2009 11:01 |
Set dead after Flash | That'sme | Infinity-Box | 9 | 08-18-2008 23:43 |
plez help i-mobile 306 Set dead after Flash | SHOEB AHMED | Infinity-Box | 4 | 08-14-2008 07:12 |
""2100 Dead After Flashing In J.a.f The Set Become Dead"" | abhijithkb | Nokia Hardware & Hardware Repair | 8 | 05-21-2008 08:40 |
plese help my set nokia 6280 is dead after flashing | digitized | J.A.F. By Jafsupport.com | 2 | 02-23-2008 14:23 |
