Old 02-11-2010, 20:05   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Simoco sm-999 new firmware detected>
SIMOCO SM-999 NEW FIRMWARE DETECTED
READED OK SET LOG:-
COM3 [VCP0] selected
module  v3.08
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read flash
====>  Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:35C0:1C18
status: FF
high speed boot Off
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
interesting cpu type found
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.89E38348.[M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0.BIN_E24EBF3F].rpl
rom info detection finished
New firmware detected (v.3.08, database date: unknown):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
device-id: 89E38348
rom info ver: 04
sw version: M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0.BIN
project-id: M500TV_Y153PA2052.00.0, 3FBF4EE2
code offset: 00000000
ffs offset/size [01]: 00800000/001FF000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00800000
checking area [00000000]: 00080000-00FFFFFF...
ffs/eeprom found near: 00E00000
Detected ffs/eeprom address is non-standard: 00E00000
Posible reasons:
1. ffs/eeprom is Ok but address is non-standard
2. ffs/eeprom is damaged and can't be detected
3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make full flash backup for emergency case
3. repeat required operation
Are you sure that detected ffs/eeprom address is correct ?
autodetected ffs/eeprom address confirmed by user: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0__fullflash_20100212-002259.B0M SIMOCO SM-999
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\M500TV_Y153PA2052_PCB01_GPRS_MT6226_S01.00_0__system_log_89E38348_E24EBF3F_20100212-002608.B0X.bin
Finished, time used: 15 min 3 sec
Remove/Install battery now !
HEARE IS FILE==
The Following User Says Thank You to debmobile For This Useful Post:
Old 02-11-2010, 21:37   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hello,
Thank you very much !
We will check, prepare and upload files in support area ASAP.
Simoco sm-499 new firmware detected> debmobile Infinity-Box 2 02-19-2010 12:57
Heare is simoco sm-324 new firmware detected debmobile Infinity-Box 5 12-20-2009 16:47
<new model simoco sm-1200 new firmware detected> debmobile Infinity-Box 3 12-07-2009 09:02
Simoco sm-399 new firmware detected debmobile Infinity-Box 2 07-31-2009 17:20
Simoco Sm-498 New Firmware Detected. debmobile Infinity-Box 3 08-08-2008 10:49
Page generated in 0.16356 seconds with 10 queries
