02-17-2009, 08:37 | #1 (permalink) |
Junior Member Join Date: Jul 2008 Location: West Bengal India
Member: 823996 Status: Offline Thanks Meter: 3 | simoco sm1000 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #01 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #02 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #03 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #04 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #05 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #06 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #07 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #08 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #09 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #0A in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #0B in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #0C in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #0D in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #0E in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #0F in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb detecting chip #01 in region #00... flash: 8988C300010001:8988C300000000 flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00200000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00180000 flash: 8988C300010001:8988C300000000 checking area [00000000]: 00000000-001FFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00180000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00080000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00180000-001FFFFF detecting ffs/eeprom structure pass 1... ..... detect standard fat location pass #1... ...... detect extended fat location pass #1... ...... fat location can't be detected error: ffs/eeprom detection failed: element #1 detecting ffs/eeprom structure pass 2... ..... detect standard fat location pass #1... ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... Finished, time used: 64 sec Remove/Install battery now ! Here is the log for 1st cpu(6226): Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:7D42:E8B6 status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.CDC10BCC.[E553_Y15DBT799EN2_E553_GPRS_MT6226_S01.SM1000_00_1 .BIN_00A2DA71].rpl identification#1 detection finished device-id: CDC10BCC identification#1 protocol ver: 04 ver. sw 1: E553_Y15DBT799EN2_E553_GPRS_MT6226_S01.SM1000_00_1 .BIN ver. sw 2: SM1000.E553_Y15DBT799EN2.00.1, 8E255DFF ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 Detected ffs/eeprom address is non-standard: 00E00000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... ................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_CDC10BCC_E553_Y15DBT799EN2_E553_GPRS_MT6 226_S01.SM1000_00_1.BIN_00A2DA71_20090217-130529.B0X.bin Finished, time used: 176 sec Remove/Install battery now ! |
02-17-2009, 09:58 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, There is no firmware for 2nd sim for this phone in support area. If you will have good working phone, please, read 2nd sim flash and send it to [email protected] What to do with current phone: Power-on phone Power-off phone by phone "power" button try to repair imei for 2nd sim |
08 Feb 2008: Fly-SX220, Haier-M300, Simoco-SM1000, Fly-E100, models supported | InfinitySupport | Infinity-Box | 20 | 02-18-2008 20:31 |
SiMoCo | brinx | S-Gold Based Phones | 4 | 03-24-2006 18:07 |
Have Registion Code of SiMoCo 2.2.1 (Siemens Mobile Control) ? | ^NaT^ | Siemens-Benq RingTones and WallPapers | 5 | 02-23-2005 01:57 |
Simoco And Smelter | schmeichelsopot | E-Gold Based Phones | 0 | 02-07-2005 15:29 |
