simple question to support Hello....y want to ask if TMN SCRIPT ZTEmobile ZTE-G X990 and only x990 same????? |
The only 100% way to know it for sure: 1. select model X990 2. read full flash (it's 100% safe process) 3. send full flash backup file (or link) to [email protected] 4. in short time you will get an answer |
here it is....regardīs COM4 [VCP0] selected module v3.78 Device: ZTE-X990 Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: X990_V2_Z15_PT_D1EF113 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2 _Z15_PT_D1EF11 nfi area detection (3 cores) finished: Ok warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_ Z15_PT_D1EF113.BIN project-id: X990_V2_Z15_PT_D1EF113, 00000000 code offset: 00000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.78, database date: 03.03.2011): ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_ Z15_PT_D1EF113.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 128Mb number of areas/bytes to read: 1:08000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Users\Desktop\ZTE-X990_ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X99 0_V2_Z15_PT_D1EF113__fullflash_20110307-020628.B4M.bin Disconnect... done Finished, time used: 1235 min 57 sec Remove/Install battery now ! RapidShare AG, Cham, Switzerland ;) |
Hello, Firmware is very similar to ordinary X990, so you can try to unlock phone via "read unlock codes" - it will be no any damage for phone and codes should be read. Please, post here unlock results. |
COM4 [VCP0] selected module v3.78 Action: read unlock codes unlock method: read codes Model: ZTE-X990 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: X990_V2_Z15_PT_D1EF113 Version: ZTEMT35_09A_GEMINI_HW ==================== New firmware found (v.3.78, database date: 03.03.2011): X990_V2_Z15_PT_D1EF113 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 35793003446251 connection Ok 192 byte(s) read 38 byte(s) read Phone lock: Off Phone code: 1122 180 byte(s) read reading data... 972 byte(s) read lock[1] code: + 12345678 lock[2] code: + default lock[3] code: + 1122 lock[4] code: - default lock[5] code: - default lock[6] code: + default lock[7] code: + default if code is not accepted by phone: - make full flash backup for emergency case - flash phone with good eeprom file - Power-On phone without sim-card - Power-Off phone - read unlock codes - restore original imei Finished, time used: 18 sec Remove/Install battery now ! code np not acept by fone....regardīs |
Is it really simlocked (operator locked) phone or simfree phone ? |
Hello, You can make unlock via "smart fast" unlock method, as I can see phones with similar firmware was unlocked via "smart fast" method without problems. |
COM4 [VCP0] selected module v3.78 Action: "sp-unlock" unlock method: smart fast Model: ZTE-X990 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: X990_V2_Z15_PT_D1EF113 Version: ZTEMT35_09A_GEMINI_HW ==================== New firmware found (v.3.78, database date: 03.03.2011): X990_V2_Z15_PT_D1EF113 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== 86 byte(s) read imei: 35793003446251 connection Ok 192 byte(s) read reading data... reading data #2... building new data... writing data... 180 byte(s) read reading data... warning: wrong packet cs 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 18 sec Remove/Install battery now ! |
