Old 03-06-2011, 22:10   #1 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 242
Question simple question to support
Hello....y want to ask if TMN SCRIPT ZTEmobile ZTE-G X990 and only x990 same?????
Old 03-06-2011, 23:18   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hi,
The only 100% way to know it for sure:
1. select model X990
2. read full flash (it's 100% safe process)
3. send full flash backup file (or link) to [email protected]
4. in short time you will get an answer
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 03-07-2011, 03:13   #3 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 242
here it is....regardīs
COM4 [VCP0] selected
module v3.78
Device: ZTE-X990
Checking data, wait...
Action: read flash NAND
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP
chip size: 128Mb
page/spare size: 0800/0040
pages per block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/06000000
firmware size: 32Mb
ffs size: 96Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: X990_V2_Z15_PT_D1EF113
detect NAND info...
number of areas/bytes to read: 1:001A0000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: ZTEMT35_09A_GEMINI_BOOTLOADER_V005_MT6235B_X990_V2 _Z15_PT_D1EF11
nfi area detection (3 cores) finished: Ok
warning: ffs can not be detected
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X990_V2_ Z15_PT_D1EF113.BIN
project-id: X990_V2_Z15_PT_D1EF113, 00000000
code offset: 00000000
rom info structure: [standard] type (07)
TCL-ID is absent
===> done
New firmware found (v.3.78, database date: 03.03.2011):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
area size: 128Mb
number of areas/bytes to read: 1:08000000
file saved: C:\Users\Desktop\ZTE-X990_ZTEMT35_09A_GEMINI_PCB01_GPRS_MT6235B_S01.X99 0_V2_Z15_PT_D1EF113__fullflash_20110307-020628.B4M.bin
Disconnect...
done
Finished, time used: 1235 min 57 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to carlos32 For This Useful Post:
Old 03-07-2011, 08:50   #4 (permalink)
Member: 130995
Hello,
Firmware is very similar to ordinary X990, so you can try to unlock phone via "read unlock codes" - it will be no any damage for phone and codes should be read.
Please, post here unlock results.
Old 03-07-2011, 10:25   #5 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 242
module v3.78
Action: read unlock codes
unlock method: read codes
Model: ZTE-X990
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: X990_V2_Z15_PT_D1EF113
Version: ZTEMT35_09A_GEMINI_HW
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or http://4shared.com
86 byte(s) read
imei: 35793003446251
connection Ok
192 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
180 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 12345678
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone
- read unlock codes
- restore original imei
Finished, time used: 18 sec
code np not acept by fone....regardīs
The Following User Says Thank You to carlos32 For This Useful Post:
Old 03-07-2011, 10:28   #6 (permalink)
Member: 130995
Is it really simlocked (operator locked) phone or simfree phone ?
Old 03-07-2011, 10:33   #7 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 242
yes itīs simlocked (operator locked)
Old 03-07-2011, 10:40   #8 (permalink)
Member: 130995
Hello,
You can make unlock via "smart fast" unlock method, as I can see phones with similar firmware was unlocked via "smart fast" method without problems.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 03-07-2011, 10:52   #9 (permalink)
carlos32's Avatar
Member: 1166261
Sonork: 100.1623881
Thanks Meter: 242
Smile
Hello,
wed this method workīs fine....cable sfr 341
module v3.78
Action: "sp-unlock"
unlock method: smart fast
Model: ZTE-X990
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
86 byte(s) read
connection Ok
192 byte(s) read
reading data...
reading data #2...
building new data...
writing data...
180 byte(s) read
reading data...
warning: wrong packet cs
972 byte(s) read
writing data...
verifying...
verification Ok
done
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-07-1999 00:47
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 23:36
Page generated in 0.38863 seconds with 8 queries
