09-28-2008, 05:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2004
Member: 73455 Status: Offline Thanks Meter: 23 | j100i sony ericsson SUBSIDY PASSWORD |
09-28-2008, 07:53 | #2 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | bro just use simple k750 cable using uni cables(if u hav)check out the pinouts n it will work.. reconnect d battery several times and it will work...tested 100% |
The Following User Says Thank You to azeem781986 For This Useful Post: |
09-28-2008, 09:07 | #3 (permalink) |
Member: 73455 Status: Offline Thanks Meter: 23 | thank u so much now the phone is unlocked..... bwena mano sa infinity namin more to come...hehehehe COM23 selected Action: unlock Device: Sony-Ericsson J100 Checking data, wait... Connect... Press and HOLD Power button... connection mode: 02 Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW version: R1D009 HW version: _NC2 LP ver: CXC1250396_lp_EU2_R1D009 Flex ver: FFN_NC2_01_FILE 000 imei otp: 354155011464710 Check Flash-1 Done Check Flash-2... reading ... file saved: C:\Program Files\InfinityBox\Moto01\backup_eeprom_calibration _354155011464710_20080928-150644.80E.bin imei eeprom: 354155011464710 Check Flash-2 Done Write... Write Done Finished, time used: 58 sec Remove/Install battery now ! |
The Following User Says Thank You to topnoyze For This Useful Post: |
09-28-2008, 20:15 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
Sony Ericsson w200 solution pack | udayangacnu | Sony Ericsson Hardware Repair | 0 | 03-29-2010 18:52 |
Cant unlock Sony-Ericsson-J132 | rajhcl0 | Infinity-Box | 3 | 03-29-2010 18:28 |
i need software - Sony Ericsson J100i flasher-unlockerv1.12SC | Mr/konsowa | VygisToolbox | 3 | 08-10-2006 15:04 |
New version - Sony Ericsson J100i flasher-unlocker v1.14SC - FIRST in the world | Gobi | VygisToolbox | 7 | 07-18-2006 10:13 |
helppppppppppppp sony ericsson J100i | elmehdi59 | Cruiser Suite | 0 | 06-21-2006 08:01 |
