08-22-2011, 16:55 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | n73 flasherror how to deal with COM34 [VCP0] selected module v4.00 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware D320M00_PCB01_GPRS_MT6223_S00.M_RD3230422_M00201_V 1_3_0_0M0513__fullflash_20110822-162802.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:78BF:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 00000000000000:00000000000000 flash: 00000000000000:00000000000000 number of flash chip/regions detected: 02/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFF0043:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (07) TCL-ID is absent rom info detection finished rom info ver: 07 sw version: D320M00_PCB01_GPRS_MT6223_S00.M_RD3230422_M00201_V 1_3_0_0M0513.BIN project-id: M.RD3230422.M00201.V1.3.0.0M0513, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (07) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFF0043:2088C400000000 checking area [00000000]: 00080000-00FFFFFF... ffs/eeprom found near: 00800000 Detected ffs/eeprom address is non-standard: 00800000 Posible reasons: 1. ffs/eeprom is Ok but address is non-standard 2. ffs/eeprom is damaged and can't be detected 3. ffs/eeprom is Ok but detected incorrectly (f.e. unknown ffs/eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make full flash backup for emergency case 3. repeat required operation Are you sure that detected ffs/eeprom address is correct ? autodetected ffs/eeprom address confirmed by user: 00800000 detecting ffs/eeprom size... ffs/eeprom size: 00800000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00800000-00FFFFFF firmware area: 00000000-007FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: D320M00_PCB01_GPRS_MT6223_S00.M_RD3230422_M00201_V 1_3_0_0M0513__ffs... file saved: C:\Program Files\InfinityBox\MModule\D320M00_PCB01_GPRS_MT622 3_S00.M_RD3230422_M00201_V1_3_0_0M0513__ffs_201108 22-164846.B0E.bin flash: 2088C4FFFF0043:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 2088C4FFFF0043:2088C400000000 Write: Firmware error: error# 00000092 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 00576000:00002000 error: error# 00000092 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 0057E000:00002000 error: error# 00000092 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 0057E000:00002000 error: error# 00000092 10:4[01]: Program fail or program sequence error when set with SR[5,7]. 02:1[01]: Block locked during program or erase; operation aborted. error: flash write error: 0057E000:00002000 error: write operation failed Write Fail Finished, time used: 16 min 21 sec Remove/Install battery now ! |
+ First photos of the Nokia N73 unveiled! | apocalypso | Off Topic Zone | 8 | 05-27-2008 13:47 |
cfx65 flasherror | Max Power | Infinity-Box | 3 | 03-15-2007 03:00 |
+ New Nokia devices leaked; Nokia N73 and Nokia N93! | apocalypso | Nokia Base Band 5 ( BB-5 ) | 6 | 07-01-2006 08:18 |
+ Three New N Series Phones N72; N73 & N93 | apocalypso | Nokia Base Band 5 ( BB-5 ) | 7 | 06-11-2006 19:13 |
