Old 08-20-2011, 14:28   #1 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 664
Sir i cant flash phone with translated firmware
i read and translated fullflash to russian
there is only 2 languages English and Turkish
but with translated firmware phone is not powering on
while writing coming to 47% and stopping
please help
here is link for fullflash
Deposit Files
Thanks
Old 08-20-2011, 15:14   #2 (permalink)
s.Mobi's Avatar
Member: 7436
Thanks Meter: 399
Please, upload log file from MModule - maybe problem not in edited file, but in MModule. Need log file from it for checking.
The Following 2 Users Say Thank You to s.Mobi For This Useful Post:
Old 08-21-2011, 10:41   #3 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 664
here is the log file
Deposit Files
Old 08-22-2011, 21:44   #4 (permalink)
s.Mobi's Avatar
Member: 7436
Thanks Meter: 399
Here is part of your log:
==== [20.08.2011 15:13:33] ====
COM8 [VCP0] selected
module  v3.98
Device: _Autodetect MT6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_1_8V_PR_R1_TURKEY.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
enhanced security fix enabled
====>  Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:F803:0009
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====>  Initialize ...
flash: 01007E00260003:0AEA0000000000
flash: AMD/Fujitsu std [T 00FFx020000 0004x008000] 32Mb
otp offset: 01FE0000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====>  Set baud ...
460800
Set baud Done
====>  Initialize bootcode ...
Initialize bootcode Done
====>  Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA
total flash region size: 02000000
usb bootloader detect...
usb bootloader (chip) is present: 00020000
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.98, database date: 25.07.2011):
TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_1_8V_PR_R1_TURKEY_V0_7.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_1_8V_PR_R1_TURKEY_V0_7.BIN
project-id: E502-2_1.8V_PR_R1_TURKEY_V0.7, 00000000
code offset: 00020000
ffs offset/size [01]: 01800000/00800000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 01800000
standard ffs/eeprom offset confirmed: 01800000
detecting ffs/eeprom size...
ffs/eeprom size: 00800000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:01800000-01FFFFFF
firmware area: 00000000-017FFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
detecting firmware version...
firmware version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_1_8V_PR_R1_TURKEY_
detecting firmware build...
firmware date/time: 2010-06-30 18-55
hw1: TINNO25_08A_GEMINI_HW
hw2: 08A_TINNO25_08A_GEMINI
done
detecting product-id...
done
detecting languages...
language parameters detected
detected languages: En Tr
Check firmware integrity Done
====>  Check firmware content ...
Check firmware content Done
====>  Backup required data ...
reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_1_8V_PR_R1_TURKEY___ffs...
file saved: D:\InfinityBox\MModule\TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E502-2_1_8V_PR_R1_TURKEY___ffs_20110820-152039.B0E.bin
Backup required data Done
====>  Patch required data ...
Patch required data Done
====>  Special operation ...
Special operation Done
====>  Write ...
sec info (fast) detection...
usb bootloader (file) is present: 00020000
rom info relocation detected
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
error: no any expected answer
error: flash write error: 01DC0000:00002000
error: write operation failed
Write Fail
Finished, time used: 8 min 14 sec
Remove/Install battery now !
WARNING ! Settings will be cleared, user data erased, Imei set to default value !
Make flash backup before this procedure !
Do you want to continue ?
What i can see? MModule write you about send your firmware to Infinity BOX support, why you can't make this? And second - from your log i can see problem in MModule with flash writing, and... - why you don't use latest version of MModule, why you use version 3.98 if exist 3.99 ?
Old 08-23-2011, 08:15   #5 (permalink)
Member: 1293050
Sonork: 100.1625975
Thanks Meter: 664
i downloaded MModule v4.01 do you really think
matter is MModule
please can you translate fullflash and upload it
i will write your flash
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Page generated in 0.27930 seconds with 8 queries
