Old 09-10-2015, 13:35   #1 (permalink)
Member: 307225
Thanks Meter: 45
Sir JayDi Need Your Help With Qmobile A120 (Invalid IMEI)
Hi Sir I Have One Qmobile A120 (MT6572) With Invalid IMEI
I Did These Steps
Flash With Factory Firmware (Same)
Flash With Bin File (Same)
Repair Basband + Repair IMEI + Write NV RAM (Still Same)
Possible Get Any Help To Fix This Phone ?
Here Is Phone Log
Card found: S/N 0B4F:0129
Chinese Miracle II [MTK module] v 1.29
Load File
File_Info : s4031a
FileVersion : MT6572
Load File Ok
Operation : Flash [ v1.29 ]
======= Flash
Files set for flashing :
[ MCU ] : MT6572__QMOBILE__QMobile_A120__ALPS.JB3.MP.V1__And roid_4.2.2__20140410_103138.ispff
Wait for phone...
Phone found! [ 73 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 90014A4834473164048604A215576177
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048604A215576177
[eMMC] : FLASH_LEN : 0x00000000E7000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Brand : QMobile
ProdName : A120
ProdModel : QMobile A120
Device : A120
AndroidVer: 4.2.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.JB3.MP.V1
ISPFF ID : 6572 , TARGET ID : 6572
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
Init Ok , Sending blocks ...
Write done , 3696 blocks sent
Done!
Elapsed: 00:09:24
Reconnect Power/Cable!
Operation : Write NVRAM [ v1.29 ]
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[NVCheck] : BBID : MT6572 , NVID : MT6572
[NV] : Write Ok!
[Info] : NVRAM Repair on erased/damaged phone :
1. Fix Unknown BaseBand
2. Repair Security
3. Write NVRAM
Done!
Elapsed: 00:00:30
Operation : Fix Unknown BaseBand [ v1.29 ]
User accepted FixBB operation!
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Step #1
Step #1 ... Ok
Step #2
Step #2 ... Ok
Reset Done!
Done!
Elapsed: 00:00:17
Operation : Repair Security [ v1.29 ]
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 353615060857271
Set IMEI [01] : 353615065857276
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 73 ]
Sync...
PostCheck Ok! Repair done!
Done!
Elapsed: 00:00:41
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[NV] : Write Ok!
2. Repair Security
3. Write NVRAM
Done!
Elapsed: 00:00:17
The Following User Says Thank You to Abid Hussain For This Useful Post:
Old 09-10-2015, 13:39   #2 (permalink)
Member: 307225
Thanks Meter: 45
Here Identify Log From Phone (With Extended Log)
Operation : Check / Read Info [ v1.29 ]
Wait for phone...
Phone found! [ 73 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : QMobile
ProdName : A120
Device : A120
AndroidVer: 4.2.2
MTKxCPU : MT6572
EXTRA :
LCD [0] : ili9806h_wvga_halfram_dsi_txd
LCD [1] : ili9806h_wvga_halfram_dsi_tkc
LCD Res : 800x480
TOUCH [0] : ektf2k
TOUCH [1] : cy8ctst242
TOUCH [2] : ft6x06
CAM [0] : ov5645_mipi_yuv
CAM [1] : ov5646_mipi_yuv
CAM [2] : hi704_yuv
CAM [3] : sp0a19_yuv
MODEM : mt6572_s4031a_hspa_gemini_pk_850_900_1800_1900_b1b 8
LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG th_TH pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ iw_IL my_MM km_KH ko_KR ur_PK fa_IR hdpi
Done!
Elapsed: 00:00:16
Old 09-10-2015, 14:47   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,662
What BaseBand state now?
Settings - About - BaseBand version
Old 09-10-2015, 21:43   #4 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
Same prob my s4 clone
Old 09-11-2015, 09:24   #5 (permalink)
pradeep_kus's Avatar
Member: 459784
Sonork: 100.1592448
Thanks Meter: 1,456
Same - Question ?
Old 09-12-2015, 07:47   #6 (permalink)
Member: 307225
Thanks Meter: 45
There Is No BaseBand Info (When Go To Setting > About)
Old 09-12-2015, 08:01   #7 (permalink)
Member: 307225
Thanks Meter: 45
Old 09-12-2015, 08:05   #8 (permalink)
Member: 1053684
Thanks Meter: 16
flash with factory frimware with sp flash tool and choise format and download
chel after flash have baseband
Old 09-12-2015, 08:12   #9 (permalink)
Member: 1189561
Thanks Meter: 176
write working bin file then write imei
Old 09-12-2015, 08:20   #10 (permalink)
Member: 307225
Thanks Meter: 45
Read My 1st Post (Already Did Same)
Old 09-12-2015, 08:27   #11 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,441
some set show baseband after insert sim check this once
Old 09-12-2015, 08:33   #12 (permalink)
Member: 307225
Thanks Meter: 45
Same With Insert Sim Card
Old 09-12-2015, 08:54   #13 (permalink)
Member: 307225
Thanks Meter: 45
Try This Method Still Same ( Invalid IMEI )
Old 09-12-2015, 09:57   #14 (permalink)
JayDi's Avatar
Member: 462970
Erase flash fully.
Flash FW.
Start phone. Play with it little.
Repair security.
Check after.
NOT WRITE NVRAM and NOT fix BB.
Old 09-12-2015, 10:19   #15 (permalink)
Member: 307225
Thanks Meter: 45
OK Let Me Check Sir
Will Post Result
Page generated in 0.42041 seconds with 7 queries
