Old 09-23-2008, 23:15   #1 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
Thanks Meter: 793
Problem speed in pin finder
i need to repair my phone
pin ditected wint pin finder ok
here log
software version: 1.14
cable type: 2x7 (L14B)
platform: MT: MT62xx (autodetect)
searching adapter at COM4...
adapter found, version: 2000
pins: 14, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed -------------------------------- speed fixed in 19200
CPU: MT6205
result: Rx:9 Tx:2
time required: 57 sec
Power On !
with soft infinity all is ok speed selected slowest
COM4 selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
19200 fixed here again speed in 19200
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E221A2201:18E59F00000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
detecting chip #01 in region #00...
error: no any expected answer: wrong answer after chip cfi request
error: no any expected answer: wrong answer after chip id request
Initialize Done
Set baud...
slowest
error: can't work at this speed, use lower speed
Set baud Fail
Finished, time used: 24 sec
Remove/Install battery now !
phone no repaired problem speed in pin finder
to infinitysupport
plz fixe the problem
Old 09-24-2008, 14:15   #2 (permalink)
Member: 162536
Thanks Meter: 5
here log
pins: 14, plain
power cycles: 1
power-off delay: 20
start Rx/Tx: 1/1
Initializing...
detecting pins...
CPU: MT6205
result: Rx:9 Tx:2
Power On !
COM4 selected
Boot...
Connecting, wait...
CPU: MT6205
Boot Done
Initialize...
Initialize Done
Set baud...
slowest
Set baud Fail
to infinitysupport
Go to CHINESE MIRACLE software and change speed to any number less than
the current speed you are using and your problem will be solved.
Old 09-24-2008, 16:00   #3 (permalink)
Member: 621121
Thanks Meter: 366
Brother 19200 is booting speed but flash&format speed is difernent
Old 09-24-2008, 22:26   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
also i would advice to find First MCU pinout and work with correct phone MCU.
right now you are trying to work with second MCU
Plz add this in pin finder ikkks Infinity-Box 2 03-14-2009 17:12
Problem rectified in Pad Finder lovingazmee PadFinder box 2 03-05-2009 16:24
problem with my pin finder tshibano Infinity-Box 1 07-17-2008 22:43
Problem To Active Pin-finder ABOUSHADY Infinity-Box 11 02-20-2008 02:42
Page generated in 0.17581 seconds with 10 queries
