08-28-2009, 18:50 | #1 (permalink) |
Banned Join Date: Jun 2009
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | Sir Need Urgent Help For 1200 Unlock(infinion cpu) Need most urgent help.I have got many(in hundreds) Nokia 1200 of china ,have infinion 7880 cpu in side. I can detect it Rx and Tx by pinfinder and can read it flash and epprom. but can not unlock it , i have tried by all method but fail. There fore need urgent help (have 36 Hrs) .Please send me unlocked file or any method from which i can unlock these phone. Important thing is that in cpf box its read full flash up to 4 Mb but here in infinity shows in kb. logs are here. Pinfinder logs by selecting e-gold cpu. software version: 1.19 cable type: 1x8 (L8A) platform: PMB: Infineon e-gold searching adapter at COM7... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold: 820000 result: Rx:7 Tx:6 time required: 16 sec Trying to Power-On... Power On ! Power On ! Power On ! And its flash and eeprom logs. COM7 [VCP2] selected module v1.69 Device: Coral-200 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: L:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-static_20090828-220204.B1E.bin loading data... data loaded reading eeprom-security... file saved: L:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-security_20090828-220204.B1E.bin reading eeprom-complete... file saved: L:\Program Files\InfinityBox\Pana01\Coral-200_eeprom-complete_20090828-220206.B1E.bin reading additional data... file saved: L:\Program Files\InfinityBox\Pana01\Coral-200_lock-area_20090828-220211.B1E.bin backup critical area Done Check memory ... error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 20 sec Remove/Install battery now ! All is ok but can not unlock it. Its file are here.i read it in pana1 exe by selecting kg375.(cpf file is also attach) http://rapidshare.com/files/272671074/1200_nokia.html http://rapidshare.com/files/272671252/LG-KG375_eeprom-complete http://rapidshare.com/files/272671428/LG-KG375_eeprom-security http://rapidshare.com/files/272671587/LG-KG375_eeprom-static_20090828-221058.B1E.bin.html http://rapidshare.com/files/272671929/LG-KG375_flash_20090828-221500.B1X.bin.html Sir please need urgent help Thanks Br,Raja |
The Following 2 Users Say Thank You to GSM-STUDENT For This Useful Post: |
08-28-2009, 20:25 | #2 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Ena Neray Na Ho Dildar Ve Age: 37
Member: 171512 Status: Offline Thanks Meter: 1,034 | hi brother post here a log when u formate ffs or unlock thanks |
The Following User Says Thank You to ehsas_ghum For This Useful Post: |
08-29-2009, 09:50 | #4 (permalink) |
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | From infinity side there is no answer. Please give some answer here Yes or no. I will be satisfied and return the phones. Thanks |
The Following User Says Thank You to GSM-STUDENT For This Useful Post: |
08-29-2009, 16:15 | #7 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Pakistan
Member: 170380 Status: Offline Sonork: 100.1577994 Thanks Meter: 3,022 | If Any one Have 1200 Infenion Chip Unlocked Then Read Its Flashes & Share Here I Think If Try To Flash It With Unlocked Firmware May In Result It Will Be Unlocked |
08-30-2009, 08:32 | #8 (permalink) | |
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | From where will get ???? Quote:
I have request same to infinity team please do some thing . If there is no direct unlock please send me unlock file, Thats why i have attach the files. Althoug thanks for sharing. Thanks Br, Raja | |
08-31-2009, 09:29 | #12 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Rawalpindi Pakistan Age: 45
Member: 190947 Status: Offline Sonork: 100.96272 Thanks Meter: 161 | nokia 1200 china copy with infonion cpu i need china Nokia 1200 (with Infineon chip7880) flash file need any 1 forum member have flash file plz help or infinity team help in this matter Ms communication Rawalpindi |
08-31-2009, 13:48 | #13 (permalink) | |
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | here is your file sir. Quote:
Here is your file but it is readed by cpf box.Infinity can not read it full file. Take it and enjoy............and open solution here......hahaha http://rapidshare.com/files/273835296/1200_nokia.html thanks Br, Raja | |
08-31-2009, 17:42 | #14 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | Quote:
No Need Flashing His Problem Is Solved,Cos i Gave Him Solution Now He Can Unlock Just In 2 Sec. | |
08-31-2009, 18:10 | #15 (permalink) | |
Member: 1058944 Status: Offline Sonork: 100.1582347 Thanks Meter: 218 | I need too sir Quote:
[email protected] Thanks BR, Raja | |
need urgent help forn 1200 r 1298 not charging | sartaj | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 12-09-2007 07:01 |
**julvir need urgent help for fizio 855** | infogsm | Redbox | 7 | 01-04-2006 18:10 |
Need urgent help for SEGAMs. | DrMobile | Phone Unlocking Codes & Maps | 8 | 05-18-2003 12:33 |
needs urgent help for s46 flasher | Dubem | x1x to x45/x50 | 2 | 04-10-2003 18:55 |
Need urgent help for Sagem 992 S5 with 16k eeprom | mr_x4you | Infineon C16X M51 & ARM7 M52 BASED | 6 | 05-02-2002 04:36 |
