02-22-2009, 05:58 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Location: filesrom.com Age: 44
Member: 86531 Status: Offline Thanks Meter: 1 | Unlock JinPeng S4166 CPU AIT605G Done. COM2 [VCP0] selected module v1.62 Device: ZTE-123 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-static_20090222-113645.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-security_20090222-113646.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-complete_20090222-113647.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_lock-area_20090222-113652.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 25 sec Remove/Install battery now ! |
The Following User Says Thank You to TX101 For This Useful Post: |
03-27-2009, 15:52 | #2 (permalink) |
Junior Member Join Date: Aug 2007
Member: 569910 Status: Offline Thanks Meter: 11 | JinPeng S4166 Phone is lock code I'm User/phone/lock code COM9 [VCP0] selected module v1.60 Device: ZTE-123 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-static_20090327-214919.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-security_20090327-214920.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-complete_20090327-214922.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 18 sec Remove/Install battery now ! but Phone is not power on Please help me full flash thank ! |
03-28-2009, 14:42 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please load file "ZTE-123_eeprom-complete_20090327-214922.B1E.bin" as eeprom write back to your phone. check if it is powering On , read full backup out and send to us we will add support for this model |
03-29-2009, 15:53 | #6 (permalink) | |
Member: 569910 Status: Offline Thanks Meter: 11 | Quote:
Thank you for reply , i'm flash backup eeprom_complete , yes > phone is power on ok ! Thank for InfinityHelp ! Code: COM9 [VCP0] selected module v1.60 Device: ZTE-123 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-static_20090329-212928.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-security_20090329-212929.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-123_eeprom-complete_20090329-212931.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 35 sec Remove/Install battery now ! Last edited by Dalat_npt; 03-29-2009 at 15:58. | |
03-29-2009, 21:16 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we need FULL flash backup (read full flash) send it to [email protected] attach this photos and problem description thank you! |
03-30-2009, 05:09 | #9 (permalink) | |
03-30-2009, 05:22 | #10 (permalink) |
Member: 569910 Status: Offline Thanks Meter: 11 | flash size 4MB , files read by Vepro : Ve-infineon = 4MB |
01-28-2011, 16:37 | #12 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Hi Infinity Team I Have Also CPU China Mobile Phone CPU: AIT605G 0734-CST90 Flash Chip: Spansion I Want To Write Correct IMEI Here Is Log Code: COM2 [VCP0] selected module v1.73 Device: Vodafone-123 Checking data, wait... Action: "repair imei" new imei: 35385XXXXXXXXXX Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_eeprom-static_20110128-201249.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z125_eep65535.cfg error: can't load database v.62962 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_eeprom-security_20110128-201250.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_eeprom-complete_20110128-201256.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_imei-area_20110128-201315.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Vodafone-123_lock-area_20110128-201334.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 1 min 18 sec Remove/Install battery now ! Finished After This Process My Phone Is Dead Have I Any Chance Again My Mobile Alive ? If No Don't Worry, But Sir Please Will Support This CPU. Because Not Support Yet Any Other Box Or Tool |
c123 unlock without remove cpu | soy | Infinity-Box | 4 | 10-09-2008 13:30 |
startech 67 dual cpu restart done by infinity | twentyonecell | Infinity-Box | 3 | 09-05-2008 12:45 |
New china CPU AIT605G | spyer | SpiderMan | 3 | 06-15-2008 07:20 |
Unlock All Mtk Cpu | smart_mobile | Chinese Models & Cloned Phones | 3 | 11-16-2007 09:21 |
