02-02-2009, 09:38 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Heart of Islam Age: 41
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | SKY SK1 flash succesfuly module v1.60 Device: Sky-SK1 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .00 ULC2GL r 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-static_20090201-214332.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-security_20090201-214333.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-complete_20090201-214339.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 459 sec Remove/Install battery now ! pin finds from pinfinder Guljee |
The Following User Says Thank You to guljee786 For This Useful Post: |
02-02-2009, 09:45 | #3 (permalink) |
Member: 762034 Status: Offline Sonork: 100.1585274 Thanks Meter: 1,448 | and after flashing phone goes to (phone lock) than(user/phone/lock code) and its ok COM4 [VCP0] selected module v1.60 Device: Sky-SK1 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 007F:22F6 Connecting Done Check hardware ... sw version: .00 ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-static_20090201-215735.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-security_20090201-215736.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-complete_20090201-215742.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Write Done Finished, time used: 25 sec Remove/Install battery now ! Guljee |
n73 flash succesfuly but still flashing white screen | tonyg_253 | Nokia Base Band 5 ( BB-5 ) | 2 | 02-03-2009 11:01 |
SKY SK1 Problem In Flashing | maplegsm | Infinity-Box | 6 | 01-22-2009 08:57 |
27 Jul 2008:Bleu-351x, Huawei-T158, Coral-100, Sky-SK1, Startech-ST21i models in test | InfinitySupport | Infinity-Box | 25 | 12-12-2008 17:04 |
SKY SK1 Not Connected | asadnow2k | Infinity-Box | 0 | 09-22-2008 15:08 |
SKY SK1 Pinout Problem | Munir Memon | Infinity-Box | 6 | 07-17-2008 09:41 |
