SKY SK1 Problem In Flashing phone came for phonelock i tried also user/phone/lockcode reset setting but not done so i flashed it flash file Now dead i also tried with all speed please solved this problem COM3 [VCP2] selected module v1.60 Device: Sky-SK1 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: .00 ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-static_20090120-122300.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-security_20090120-122300.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-complete_20090120-122301.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 23 sec Remove/Install battery now ! BR;) UMER |
also tried to New module COM3 [VCP2] selected module v1.61 Device: Sky-SK1 Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-static_20090120-125708.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-security_20090120-125709.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-complete_20090120-125710.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 23 sec Remove/Install battery now ! BR;) UMER |
Hello, Try to select model BSNL-G200 and flash phone again. Let's see results. |
COM3 [VCP2] selected module v1.60 Device: Sky-SK1 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: .00 ULC2GL Z c 0 A d 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-static_20090120-122300.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-security_20090120-122300.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sky-SK1_eeprom-complete_20090120-122301.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 23 sec Remove/Install battery now ! after restore first eeprom but still dead please do something COM3 [VCP4] selected module v1.61 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... sw version: .00 ULC2GL r 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090121-182720.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090121-182720.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090121-182721.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Eeprom Writing: Eeprom Write Done Finished, time used: 18 sec Remove/Install battery now ! only 1 file on support no eeprom no any other fw or ffs file BR;) UMER |
here is readed full flash when the set was ON http://rapidshare.com/files/18711476...3.B1X.bin.html BR;) UMER |
Hello, Sky-SK1_Nov-9-2007.B1M.bin uploaded in "main" support area. Waiting for your results. |
Great Support THANX:) Now Phone is ON but not reading sim i tried to put other sims but no success it could be software fault coz fone came for userlock problem COM3 [VCP3] selected module v1.61 Device: Digibee-BSNL-G200CF Checking data, wait... Action: flash write Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20090122-122023.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20090122-122023.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20090122-122025.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Write Done Finished, time used: 146 sec Remove/Install battery now ! BR;) UMER |
