08-25-2008, 16:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: BELARUS, Minsk Age: 44
Member: 59319 Status: Offline Sonork: 100.1606948 Thanks Meter: 82 | SL500i after flash LCD doesn't work But it worked ok before flash. ==== log opened: [25.08.2008 18:02:45] ==== Application: C:\Program Files\InfinityBox\MModule\MModule.exe Loading data, wait... [Infinity Box] v2.29 S/N: 04F1:0110 Wait... Device: Fly-SL500i Done Loading file v.02... Fly-SL500i_SL900A_MERID_PCB01_GPRS_MT6226M_S01.SL900A_ 05C_W06_08_MP_V64_E6.02R_Intel_En_Ru_Ua.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: SL900A_MERID_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V64.BIN ver. sw2: SL900A.05C.W06.08.MP.V64, 00000000 detecting languages... Languages: En Ru Ua COM1 [Serial0] selected Device: Fly-SL500i Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 14 sec Remove/Install battery now ! COM6 ready COM6 [VCP5] selected Device: Fly-SL500i Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:0DC1:C11E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN ver. sw2: SL900A.05C.W06.08.MP.V72.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 16 sec Remove/Install battery now ! COM6 [VCP5] selected Device: Fly-SL500i Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:0DC1:C11E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN ver. sw2: SL900A.05C.W06.08.MP.V72.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_UKFLY_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V72_F2.BIN]_20080825-180645.B0E.bin Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Area: Firmware flash: 89881500010001:89881500000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 1098 sec Remove/Install battery now ! WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM6 [VCP5] selected Device: Fly-SL500i Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031:0DC1:C11E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89881500010001:89881500000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL900A_MERID_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V64.BIN ver. sw2: SL900A.05C.W06.08.MP.V64, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading: eeprom[SL900A_MERID_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V64.BIN]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL900A_MERID_PCB01_GPRS_MT6226M_S01.SL900A_05C_W06 _08_MP_V64.BIN]_20080825-182801.B0E.bin flash: 89881500010001:89881500000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: 89881500010001:89881500000000 Finalization Done Finished, time used: 235 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
fly sl500i after flash dead | denny86 | Infinity-Box | 6 | 08-05-2009 19:14 |
After Flashing phone doesn't start | baocom | Nokia Base Band 5 ( BB-5 ) | 1 | 01-03-2008 00:58 |
After flashing E900 doesn't take any pictures or make Video and buletooth | mobileunlockers | Cruiser Suite | 2 | 02-11-2007 18:05 |
New c45 lcd doesn't work | kshop | x1x to x45/x50 | 4 | 06-15-2003 23:50 |
