04-27-2016, 12:59 | #1 (permalink) |
No Life Poster Join Date: Sep 2015 Location: Earth
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | ErrCode : 0xAFC Stuck On Logo tried tested Flash file and more flash files all then it Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 15010038574D423352015ED145C74123 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3BMW [eMMC] : FLASH_CID : 15010038574D423352015ED145C74123 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 86F829F96A2ADCBDD1F5E6D7D0959CF1 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6582 , Project : reallytek82_tb_jb5 , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : Only one records found, and determined as universal BL : eMMC supported by BootLoader! BL : BatteryLevel : 3696 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000001400000-0x0000000000100000 Erase : 0x0000000003100000-0x00000001CE280000 Flash Pre-Erase Done, time used : 00:00:06 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_reallytek82_tb_jb5.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0014 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : EBR2 Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:15 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Error! Something went wrong! ErrCode : 0xAFC9 Operation Failed Elapsed: 00:02:52 Reconnect Power/Cable! |
04-28-2016, 13:39 | #3 (permalink) |
Member: 2455344 Status: Offline Sonork: Ask me Thanks Meter: 420 | [Processing] FlashMemory Read-Write test [eMMC] : [SAMSUNG] , R3BMW , 0x1D2000000 , 7456 MiB [eMMC] : CID : 15010038574D423352015ED145C74123 [eMMC] : MODE : SQ-WR [FAILED : READONLY] : eMMC state seems as READ-ONLY !!!! Operation Failed Elapsed: 00:00:40 Reconnect Power/Cable! |
04-29-2016, 07:39 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | No, only change is permanent solution. Re-programmig it via some other device will make it working for temporary period. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
