-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   slt100 dead after flash (http://forum.gsmhosting.com/vbb/f296/slt100-dead-after-flash-628066/)
mzsufi 11-11-2008 20:11
i have unlocked the phone, but it was asking for master code, i decided to flash it then unlock but after flashing the phone is dead, now i can not get it to connect it again, its not powering up again.
this is the log of flash
COM20 [VCP0] selected
module v2.40
Device: Fly-SLT100
Checking data, wait...
Action: write NAND flash
read mode: 01
write: Firmware
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
source data: page only
identification#1 protocol ver: 04
ver. sw 1: SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_3 6_MP_V36.BIN
ver. sw 2: MAUI.06A.W06.36.MP.V36, 00000000
ffs offset/size: 02000000/02000000
id-page1 Ok
nfi area detection finished: Ok
Boot ...
19200 fixed
Connecting, wait...
Initializing [6228:8A02:8A02]...
CPU: MT6228
chip: 0031:0000:0101
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
version: 3.0207
loader: 3.748.0
NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb
NAND id: AD76AD76
page size: 200+10
pages/block: 20
bits i/o: 08
address cycles: 04
blocks: 1000
ram size: 00800000
NOR: 0000:000000000000 [00000000]
NAND: 00AD:007600AD0076 [04200000]
NOR chip is not installed
Initialize Done
Set baud ...
115200
Set baud Done
Identification ...
reading structure area...
detecting structure...
id-page1 Ok
identification#1 structure: 2nd [standard] generation
Identification Done
Write ...
write core area 1 of 2...
write core area 2 of 2...
error: code: A500000BF3
error: code:
error: block/offset: 000011B0/011B0000
InfinitySupport 11-11-2008 21:58
Hello,
If phone can not be connected again you need to check battery voltage and charge battery with external power supply.
mzsufi 11-12-2008 12:53
Originally Posted by InfinitySupport (Post 3838341)
Hello,
i have connected with usb power lead but still not connecting, i will try again with the battry charged
mzsufi 11-12-2008 18:09
Hello,
eaven with battery charged still no connection
pls help as customer can not wait
LuisinhoCell 11-12-2008 18:39
Look comfortable in using the 3.7vlts
InfinitySupport 11-12-2008 19:21
Hello,
If phone can not be connected you need to check battery voltage and charge battery with external power supply.
LuisinhoCell 11-12-2008 21:37
But I talked to him in a cell tests the source adjust, and put VLT 3.7 to test the unit ....
InfinitySupport 11-12-2008 23:39
Hello,
Yes. If phone hardware is Ok and battery is enough charged phone can boot in any case, even if flash chip is empty or wrong flashed.
omer123 11-13-2008 01:11
i had this experience last time and buy a new phone to cusomer there definatly somthing wrong infinity support u must do a test on fly slt1oo thanx
InfinitySupport 11-13-2008 01:31
Hello,
It may be the next problem: damaged phone hardware or damaged cable.
There is no any other way why phone can not boot, so I suggest toy yo take your phone (that you have instead of other one), charge battery, double check cable and flash it again now.
Page generated in 0.23882 seconds with 5 queries
