09-24-2017, 23:49
#1 (permalink)
Join Date: Nov 2014 Location: Pakistan/UAE/WorldWide Age: 26
Member: 2302076
Sonork: 100.1663298 Thanks Meter: 185 | Huawei BLN-L21 MT6582 Clone Flash Successfully Virus remove + Logo Hang solved Quote:
Start at : [9/24/2017 / 10:18:39 AM]
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 7001004D4D43303447581FB07F765273
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x70 , OEM : 0100
[eMMC] : FLASH_INF : [KINGSTON] , G40CM
[eMMC] : FLASH_CID : 7001004D4D43303447581FB07F765273
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E6800000
[eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB]
DEV RID : 0xB734A4A27786D8F519CC847D4BAC085F
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : y8203 , Storage : EMMC
Setting : AFF verify : Disabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Skip checking by User request!
BL : BatteryLevel : 3733 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x00000000AB200000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Preloader Download skipped by user request!
PartCount : 0012
Update PMT by user request
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:36
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:02:52
Reconnect Power/Cable!
Finish at : [9/24/2017 / 10:21:30 AM]
| NVRAM Imei Invalid Also Repaired Quote:
Start at : [9/24/2017 / 10:33:42 AM]
Operation : Write NVRAM [ v1.58 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[NV] : Data in Binary Format
[NVM] : Write Ok!
[Info] : NVRAM Repair on erased/damaged phone :
1. Fix Unknown BaseBand
2. Power On phone, check BB state
3. Write NVRAM
4. Repair Security
Done!
Elapsed: 00:00:33
Finish at : [9/24/2017 / 10:34:15 AM]
