SM-J500H MT6572 clone format error help plz Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E085F6052D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E085F6052D9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x02C024E4130424C2C1E2D273658D5A5E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Samsung ProdName : SM-J500H ProdModel : SM-J500H Device : j7252 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : J7252_2G_5.0_V1.10 20161220-2054 SECURITY : IMEI_SW [1] : 355236031121701 IMEI_SW [2] : 355236031121719 BTMAC Addr : 000046657201 WiFi MAC : 000000000000 EXTRA : LCD [0] : otm1288a_hd720_dsi_vdo LCD [1] : jd9365_hd720_dsi_vdo LCD [2] : ili9881c_hd720_dsi_vdo LCD [3] : s6d7aa6x01_dsi_vdo LCD [4] : nt35521_hd720_dsi_vdo LCD Res : 1280x720 TOUCH [0] : ft5206_new CAM [0] : s5k4ecgx_yuv CAM [1] : gc2035_yuv CAM [2] : hi253_yuv CAM [3] : gt2005_yuv CAM [4] : sp0a19_yuv CAM [5] : gc0329_yuv CAM [6] : gc0308_yuv CAM [7] : gc0328_yuv CAM [8] : gc0309_yuv CAM [9] : gc0307_yuv MODEM : keytak72_wet_jb3_gprs LOCALE : en_US es_ES zh_CN zh_TW ru_RU pt_BR pt_PT fr_FR de_DE tr_TR it_IT in_ID ms_MY vi_VN ar_EG fa_IR th_TH km_KH my_MM el_GR hdpi xhdpi -sw320dp -sw600dp -sw720dp Done! Elapsed: 00:00:17 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8C00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 7001004D4D43303447581E085F6052D9 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D43303447581E085F6052D9 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E6800000 [eMMC] : FLASH_UCP : 3688 MiB [eMMC 4 GiB] DEV RID : 0x02C024E4130424C2C1E2D273658D5A5E INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Format/Reset Error! Operation Failed Elapsed: 00:00:23 Reconnect Power/Cable! |
Read full firmware, reflash phone with this firmware. Отправлено с моего SM-G930F через Tapatalk |
emmc problem making test |
