recondition | 05-10-2017 10:36 | SM-j700F clone MT6572 HELP after try to flash SM-J700FN firmware with MT6572 also
now cannot flash back on his original backup from cm2
flashing error Code:
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 298 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 11010030303447453001475C4ECE92CD
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x11 , OEM : 0100
[eMMC] : FLASH_INF : [TOSHIBA] , 0EG40
[eMMC] : FLASH_CID : 11010030303447453001475C4ECE92CD
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
[eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB]
DEV RID : 0xD9B11B21E129F27C5103BC5CC44BCDF0
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : tangxun6572_we_l , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
****ch to HSUSB failed! Trying skip ...
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : Unknown (not supported or without battery)
BL : Flash Pre-Erase
Total blocks to Erase : 3
Erase : 0x0000000000C00000-0x0000000000100000
Erase Error! Something went wrong!
Operation Failed
Elapsed: 00:00:16
Reconnect Power/Cable!
make test Code:
Operation : HW Test [ v1.58 ]
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : 3703 mV
[Processing] FlashMemory Read-Write test
[eMMC] : [TOSHIBA] , 0EG40 , 0xEC000000 , 3776 MiB
[eMMC] : CID : 11010030303447453001475C4ECE92CD
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:01:33
any idea? |
