Old 03-08-2011, 09:51   #1 (permalink)
Member: 1187394
Thanks Meter: 14
smadl t700 big problem
i have smadl t700 dual sim when put sim the phone be off .
but when do not put sim card the phone ok .i format ffs repair imie and download new flach from support the problem is problem
can give me realy solution
thanks br.
and this log
COM24 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_00_12__T700_16m_En_Ru_Fr_Es_Id_Tr_Farsi_Pt _Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:0403:0007
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 2088C4FFFF0013:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
New firmware found (v.3.26, database date: 13.01.2011):
HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_00_15.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info ver: 05
sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_00_15.BIN
project-id: MAUI.08B.W08.52.00.15, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_00_15__ffs...
file saved: C:\InfinityBox\ChineseMiracle\HEXING25_08B_GEMINI_ PCB01_GPRS_MT6225_S00.MAUI_08B_W08_52_00_15__ffs_2 0110308-091747.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 31 min 6 sec
Remove/Install battery now !
Old 03-08-2011, 11:06   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,024
Hello,
If phone is not working fine fine even format and full flash then could be hardware fault, like could be network related or battery problem in phone.
Wr.
Old 03-08-2011, 11:07   #3 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,024
Hello,
Wr.
Old 03-08-2011, 11:19   #4 (permalink)
Member: 1187394
Thanks Meter: 14
sir
i think the problem is not battery i change it with original but i am sure the problem is network because when on the phone with sim card few sec the phone off .
without sim card the phone be ok.
what i can do !!!!
Old 03-08-2011, 11:34   #5 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 890
thanks br.
and this log
module v3.26
Action: write flash
write: Firmware
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
ffs/eeprom chip: 00
====> Write ...
done
Area: Firmware
Write: Firmware
Write Done
Finalization Done
Power on phone and dial 112 if fone goes off then its 100% HARDWARE fault.
If not goes off then try to flash with new files from support
if not found on support
then here
http://fr.gsmlibrary.com/Products+Su...r.B0M.bin.html
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 09:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 16:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Really big favour! MiMiR the WiseMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-18-1999 04:21
Page generated in 0.31513 seconds with 8 queries
