Old 05-20-2018, 13:16   #3181 (permalink)
Member: 189097
Thanks Meter: 40
=== DongleManager [Infinity] v1.70 [5/20/2018 17:41:41] ===
Box/Dongle type selected: [BEST]
Card-Reader: FT SCR2000 0
HWID: 0104917F20281292
=== Process started: 5/20/2018 17:41:41 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Contact to http://www.infinity-box.com/support/?r=2
Old 05-20-2018, 13:16   #3182 (permalink)
Member: 189097
Thanks Meter: 40
Old 05-21-2018, 06:54   #3183 (permalink)
Member: 1043909
Thanks Meter: 60,920
Originally Posted by itzshafeek View Post
yes, driver is ok,
already try another pc
Try now with another PC
Old 05-21-2018, 06:55   #3184 (permalink)
Member: 1043909
Originally Posted by Lena Flasher View Post
i allready posted a thread for sollution,and i tried.but problem still exist
when i try to update smart card firmware getting this message
=== DongleManager [Infinity] v1.70 [19-05-2018 00:16:37] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
HWID: 0000431817B14082
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 584D4318
Firmware version: 0136.02
=== Process started: 19-05-2018 00:16:38 ===
Server answer:[0031] Dongle identification data damaged.
help me to solve
what i need to do next
i formatted my pc and installed a fresh os
Hello,
Why do you use debugger and other crack tools with Infinity software ?
Old 05-21-2018, 06:56   #3185 (permalink)
Member: 1043909
Originally Posted by gsmpointhrp View Post
=== DongleManager [Infinity] v1.70 [5/20/2018 13:03:16] ===
Searching...
Card-Reader: USB CCID Smart Card Reader 0
HWID: 0002E586FF021982
Reading...
Serial No (S/N): 2DD5E586
=== Process started: 5/20/2018 13:03:22 ===
Hello,
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software.
What to do now:
- Delete fault.bin file from software folder (if you have it there)
- Install latest Infinity software updates
- Run DongleManager
- Update Dongle firmware
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 05-21-2018, 06:56   #3186 (permalink)
Member: 1043909
Hello,
What to do:
1. Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - http://www.infinity-box.com/support/?r=6
OR
1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
2. Run DongleManager
3. Update Dongle firmware
- DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours
- DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle !
Old 05-21-2018, 09:53   #3187 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
Hello Dear Team Please Help
Smart Card misconfiguration
Dongle Manager Info :
=== DongleManager [Infinity] v1.70 [5/21/2018 14:43:42] ===
Searching...
HWID: 000125B17D314082
Serial No (S/N): D9C325B1
Box/Dongle misconfiguration
Diagnostic code: 5A
"UK Edition" status: Off
Last launched Application: 0034 v.0136
=> Activations:
- 00: Infinity-Box/Dongle v.0136
Diagnostic Key: 7F01B5D526311DA0
Dongle Manager Update Error :
=== DongleManager [Infinity] v1.70 [5/21/2018 14:43:57] ===
Box/Dongle type selected: Infinity-Box/Dongle
Reading...
=== Process started: 5/21/2018 14:43:59 ===
Old 05-21-2018, 11:06   #3188 (permalink)
Member: 2713959
Thanks Meter: 5
Originally Posted by YellowBoss View Post
Hello,
I used it to crack oppo flash tool, that time i opened cm2 for removing a frp, i don't know that cm2 will lock, please help me
Old 05-21-2018, 18:08   #3189 (permalink)
Member: 174330
Sonork: 100.101441
Thanks Meter: 10
=== DongleManager [Infinity] v1.70 [21.05.2018 20:04:21] ===
Card-Reader: Generic CCID Smart Card Reader 0
HWID: 0007656F19801292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): 1964656F
Firmware version: 0118.04
=== Process started: 21.05.2018 20:04:25 ===
Server answer:[0006] Your account is temporary suspended.
See problem reason in log file
Old 05-22-2018, 07:44   #3190 (permalink)
Member: 148515
Thanks Meter: 19,534
Hello,
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software.
What to do now:
- Run DongleManager
Old 05-22-2018, 07:46   #3191 (permalink)
Member: 148515
Reading...
As I can see this dongle has a problem since last year.
Do you have another card-reader ? Best results for today with Alcor card-readers.
Old 05-22-2018, 07:49   #3192 (permalink)
Member: 148515
answered in other thread
Old 05-22-2018, 10:21   #3193 (permalink)
Member: 1884955
Sonork: 1593864
=== DongleManager [Infinity] v1.72 [2018-05-22 11:19:10] ===
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 000087787CEA4082
Reading...
Serial No (S/N): C7E58778
Firmware version: 0135.02
=== Process started: 2018-05-22 11:19:11 ===
Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today !
Old 05-22-2018, 10:52   #3194 (permalink)
Member: 1292778
Thanks Meter: 22
=== DongleManager [Infinity] v1.72 [22.05.2018 12:31:58] ===
HWID: 0106A18218571292
Reading...
Serial No (S/N): F907A182
Firmware version: 0122.02
=== Process started: 22.05.2018 12:31:59 ===
=== DongleManager [Infinity] v1.72 [22.05.2018 12:51:34] ===
Searching...
Diagnostic code: 30
"UK Edition" status: On
=> Activations:
- 03: [BEST] v.0122
Diagnostic Key: 7F5BF3576F49A3CB
Old 05-22-2018, 10:52   #3195 (permalink)
Member: 1292778
Thanks Meter: 22
Hello everybody! Help
Page generated in 0.28107 seconds with 9 queries
