07-02-2018, 11:33 | #3316 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Quote:
BR, | |
07-02-2018, 12:23 | #3317 (permalink) | |
07-02-2018, 12:26 | #3318 (permalink) | |
07-02-2018, 19:39 | #3320 (permalink) |
Junior Member Join Date: Mar 2009
Member: 998606 Status: Offline Sonork: nadir Thanks Meter: 2 | Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. please give me any solution |
07-02-2018, 20:35 | #3321 (permalink) |
Member: 691388 Status: Offline Thanks Meter: 371 | Me again I need one more slot for update, after adding 1 Year new support for CM2. Code: === DongleManager [Infinity] v1.72 [7/2/2018 22:21:31] === Searching... Card-Reader: FT SCR2000 0 HWID: 0007926B20881292 Box/Dongle found: [BEST] Serial No (S/N): BAB2926B Firmware version: 0122.02 "UK Edition" status: Off Last launched Application: 0040 v.0200 => Activations: - 00: Infinity-Box/Dongle v.0136 - 03: [BEST] v.0122 - 07: #7 === DongleManager [Infinity] v1.72 [7/2/2018 22:21:38] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0007926B20881292 Box/Dongle found: [BEST] Reading... Serial No (S/N): BAB2926B Firmware version: 0122.02 === Process started: 7/2/2018 22:21:40 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 377/9937 Error upgrading applets: Card returned error - 0000 at 377/9937 Disconnected |
07-03-2018, 20:24 | #3324 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. Run DongleManager 3. Update Dongle firmware - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries for 24 hours - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
07-03-2018, 20:25 | #3325 (permalink) | |
07-05-2018, 12:51 | #3326 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1847146 Status: Offline Thanks Meter: 0 | HELP NEEDED === DongleManager [Infinity] v1.72 [7/5/2018 14:48:41] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00004B0F176D4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 6E254B0F Firmware version: 0136.02 === Process started: 7/5/2018 14:48:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
07-05-2018, 20:56 | #3327 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware | |
07-07-2018, 09:59 | #3328 (permalink) |
Junior Member Join Date: Sep 2008
Member: 872306 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [07/07/2018 09:58:04] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 01099169147D1292 === Process started: 07/07/2018 09:58:04 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
07-08-2018, 09:22 | #3329 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2423833 Status: Offline Thanks Meter: 9 | After down load Virtual Serial Port Driver v8.0.428 === DongleManager [Infinity] v1.70 [07/07/2018 23:25:49] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 0000CF861A224082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 245BCF86 Firmware version: 0136.02 === Process started: 07/07/2018 23:25:50 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
07-09-2018, 08:03 | #3330 (permalink) |
Freak Poster Join Date: Nov 2007 Location: INDIA
Member: 624348 Status: Offline Sonork: 100.1589208 Thanks Meter: 39 | i activated my dongle for sm module from gsmserverfastest , they are saying its activated but unable to ubdate === DongleManager [Infinity] v1.72 [09-07-2018 12:30:50] === Searching... Card-Reader: SCM Microsystems Inc. SCR33x USB Smart Card Reader 0 HWID: 0004457901171292 Box/Dongle found: [BEST] Serial No (S/N): 015A4579 Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0000 v.0000 => Activations: - 03: [BEST] v.0122 - 07: #7 |
