01-10-2019, 11:54 | #3889 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 682640 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.72 [10/01/2019 10:53:16] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0116979510461772 === Process started: 10/01/2019 10:53:16 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Please advise. Tried with Alcor and Fetian drivers. |
01-10-2019, 12:39 | #3890 (permalink) |
Freak Poster Join Date: Feb 2009 Location: U.P. Great INDIA
Member: 973277 Status: Offline Thanks Meter: 200 | === DongleManager [Infinity] v1.72 [1/10/2019 17:06:04] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0003A66400001942 Box/Dongle found: CDMA-Tool Serial No (S/N): 0751A664 Firmware version: 0122.02 "UK Edition" status: On Last launched Application: 0040 v.0100 => Activations: - 00: Infinity-Box/Dongle v.0136 - 01: CDMA-Tool v.0122 - 07: #7 Dongle firmware version v0136 software says its outdated but Dongle manager said everything is updated |
01-10-2019, 15:57 | #3891 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1047753 Status: Offline Thanks Meter: 1 | infinity box cm2 dongle update failed after that bo x dongle not found Serial No (S/N): 284D69DB Firmware version: 0118.02 "UK Edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 00: Infinity-Box/Dongle v.0118 === DongleManager [Infinity] v1.72 [9/26/2018 21:36:47] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 000069DB18164082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 284D69DB Firmware version: 0118.02 === Process started: 9/26/2018 21:36:51 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0005] Authentication failed! Dongle is not Registered yet ? You should "Register" before you start update ! Click to "Yes" to start Registration process. If you are already registered click to "No" === Process started: 9/26/2018 21:37:50 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Card returned error - 0000 at 4180/8391 Error upgrading applets: Card returned error - 0000 at 4180/8391 Disconnected === DongleManager [Infinity] v1.72 [9/26/2018 21:38:35] === Box/Dongle type selected: Infinity-Box/Dongle now ==== [1/10/2019 20:24:04] ==== Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.70 [1/10/2019 20:24:08] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000069DB18164082 Box/Dongle is not found its new dongle first time updated |
01-10-2019, 22:49 | #3892 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
01-10-2019, 22:55 | #3893 (permalink) | |
It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ | |
01-10-2019, 22:56 | #3894 (permalink) | |
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect ONLY one Infinity Box/Dongle to PC | |
01-10-2019, 22:58 | #3896 (permalink) | |
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
01-11-2019, 12:25 | #3898 (permalink) | |
Member: 682640 Status: Offline Thanks Meter: 1 | Quote:
Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0007808010321292 === Process started: 11/01/2019 11:22:53 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 Sorry, correct card now inserted. Same results. Please advise next steps. | |
01-11-2019, 12:28 | #3899 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
01-11-2019, 12:33 | #3900 (permalink) |
Member: 682640 Status: Offline Thanks Meter: 1 | Hi. Yes. Special Drivers Installed Tried on another PC and got this result. === DongleManager [Infinity] v1.72 [11/01/2019 11:30:42] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 0007808010321292 === Process started: 11/01/2019 11:30:43 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 0000 at 2486/8507 Disconnected |
