03-15-2019, 10:02 | #4036 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
03-15-2019, 10:03 | #4037 (permalink) | |
03-15-2019, 16:04 | #4038 (permalink) |
Insane Poster Join Date: Mar 2005 Location: Backi Petrovac
Member: 129300 Status: Offline Thanks Meter: 19 | It's Done! === DongleManager [Infinity] v1.72 [3/15/2019 16:04:13] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001DFB0FF021982 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 0761DFB0 Firmware version: 0137.02 "UK Edition" status: On Last launched Application: 001A v.0448 => Activations: - 00: Infinity-Box/Dongle v.0137 - 03: [BEST] v.0122 - 05: Content Extractor v.0122 - 06: #6 - 07: #7 => External Activations: - SPT Thanks man. |
03-29-2019, 10:22 | #4040 (permalink) |
No Life Poster Join Date: Feb 2012 Age: 39
Member: 1724862 Status: Offline Thanks Meter: 448 | === DongleManager [Infinity] v1.72 [3/24/2019 0:24:11] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 1 HWID: 000137EA7F634082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): F89A37EA Firmware version: 0137.02 === Process started: 3/24/2019 0:24:12 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
03-29-2019, 11:07 | #4041 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
04-03-2019, 15:18 | #4042 (permalink) |
Junior Member Join Date: Dec 2012
Member: 1850934 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [03.04.2019 18:18:33] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0107A17B24881292 === Process started: 03.04.2019 18:18:33 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. |
04-03-2019, 16:25 | #4043 (permalink) | |
04-03-2019, 21:20 | #4044 (permalink) |
Member: 1850934 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [04.04.2019 0:19:03] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0107A17B24881292 === Process started: 04.04.2019 0:19:03 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Error upgrading applets: Card returned error - 0000 at 261/9995 Disconnected |
04-03-2019, 22:03 | #4045 (permalink) | |
04-05-2019, 14:05 | #4047 (permalink) |
Member: 1850934 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [05.04.2019 17:05:10] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0107A17B24881292 === Process started: 05.04.2019 17:05:11 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. |
04-05-2019, 14:27 | #4048 (permalink) | |
04-09-2019, 07:23 | #4049 (permalink) |
Crazy Poster Join Date: Mar 2016 Location: 1205,motalab plaza dhaka.
Member: 2543177 Status: Offline Thanks Meter: 18 | === DongleManager [Infinity] v1.70 [4/9/2019 12:23:08] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00008F1813114082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 76C88F18 Firmware version: 0136.02 === Process started: 4/9/2019 12:23:09 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0007] No updates found for your Smart-Card. DO NOT try more today ! |
04-09-2019, 10:16 | #4050 (permalink) | |
It looks like your dongle support period is expired. How to check - https://www.infinity-box.com/doc/?r=17 If support is expired please contact to your seller and renew support - https://www.infinity-box.com/buy/ | |
