01-30-2017, 21:53 | #766 (permalink) | |
What to do: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - http://www.infinity-box.com/support/?r=6 Also you can insert Smart-Card into another Card-Reader. 2. Run DongleManager 3. Update Dongle firmware now ONLY ONE TIME - DO NOT update Smart-Card many times otherwise your account will be locked automatically after 3 tries - DO NOT use any kind of usb sharing/trace/spy/debug software to avoid problem with Dongle ! | |
01-30-2017, 21:55 | #767 (permalink) | |
How to check - http://www.infinity-box.com/doc.php?id=17 If you have active support - run DongleManager software and update Box/Dongle firmware. If support is not active - please contact to any seller and renew support. | |
01-30-2017, 21:57 | #768 (permalink) | |
01-31-2017, 06:05 | #769 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: trichy
Member: 651994 Status: Offline Sonork: n/a Thanks Meter: 62 | Quote:
01-31-2017, 07:55 | #771 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2415930 Status: Offline Thanks Meter: 0 | cm2 not working DongleManager [Infinity-Box] v1.67 [1/30/2017 6:21:11 PM] PC HWID: 691D6095E8978810BF425CE83FA755B5 Scanning... Card-Reader: FT SCR2000 0 HWID: 010062761C6A1292 Box/Dongle is not found plz tell me solution |
01-31-2017, 09:57 | #772 (permalink) | |
Freak Poster Join Date: Jul 2012 Location: Iran < Milad.B >
Member: 1784663 Status: Offline Sonork: 100.1618770 Thanks Meter: 62 | hi after new update for cm2 qlm 1.10 need update firmware and atfer that again my dongle dead ;/ Quote:
01-31-2017, 10:39 | #773 (permalink) |
Member: 2415930 Status: Offline Thanks Meter: 0 | DongleManager [Infinity-Box] v1.67 [1/30/2017 6:21:11 PM] PC HWID: 691D6095E8978810BF425CE83FA755B5 Scanning... Card-Reader: FT SCR2000 0 HWID: 010062761C6A1292 Box/Dongle is not found plz tell me solution |
01-31-2017, 12:22 | #774 (permalink) |
Freak Poster Join Date: Dec 2012 Location: searching......... Age: 43
Member: 1852490 Status: Offline Sonork: 100.1668568 Thanks Meter: 132 | hello tram having problem with my cm2 dongle in today morning after download new update qualcomm dongle need firmware update i download latest exe dongle manager & update firmware normal i do this may time but i get error in update hear is logs now not show in dongle manger for update ==== [1/31/2017 10:45:14 AM] ==== Scanning... Box/Dongle found: Main Infinity-Box/Dongle HWID: 0202AC7024881292 Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 1/31/2017 10:45:32 AM ---------- DongleManager [Infinity-Box] v1.67 [1/31/2017 10:45:32 AM] PC HWID: C9C56D009F3118207B70E0987C3322B4 Card-Reader: FT SCR2000 0 HWID: 0202AC7024881292 Type: Main Infinity-Box/Dongle S/N: CEF5AC70 Version: 0134.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Last APDU: 133 sec Card returned error - 0000 at 29/8500 Error upgrading applets: Card returned error - 0000 at 29/8500 Disconnected plz replay team as soon as possible ( i have activate this for 2 years ) |
01-31-2017, 13:07 | #775 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | DongleManager [Infinity-Box] v1.67 [1/31/2017 5:36:08 PM] PC HWID: E516823C5327366B1292F31953C54033 Scanning... Box/Dongle found: Main Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 6 HWID: 0001285700001942 Box/Dongle Serial No (S/N): 67EB2857 Firmware version: 0134.02 "UK edition" status: Off Last launched Application: 0030 v.0158 => Activations: - 00: Main Infinity-Box/Dongle v.0134 - 03: [BEST] v.0122 - 04: Pin-Finder Adapter but fail to open the new software |
01-31-2017, 13:16 | #776 (permalink) | |
Member: 1852490 Status: Offline Sonork: 100.1668568 Thanks Meter: 132 | Quote:
2nd log Box/Dongle type selected: Main Infinity-Box/Dongle ---------- Process started: 1/31/2017 5:13:59 PM ---------- DongleManager [Infinity-Box] v1.67 [1/31/2017 5:13:59 PM] PC HWID: 22711E555051803ABC513BC0653532F3 Card-Reader: FT SCR2000 0 HWID: 0202AC7024881292 Type: Main Infinity-Box/Dongle S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 | |
01-31-2017, 13:19 | #777 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Quote:
As Per Log Main Infinity-Box/Dongle v.0134 You Need To Update Card Firmware - "v.0135" Then It Will Work. | |
The Following User Says Thank You to hitech care For This Useful Post: |
01-31-2017, 16:17 | #778 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Poland
Member: 1709265 Status: Offline Thanks Meter: 41 | Now OK Thank You !!! Code: Box/Dongle type selected: [BEST] Box/Dongle found: [BEST] ---------- Process started: 2017-01-31 16:14:56 ---------- DongleManager [Infinity-Box] v1.67 [2017-01-31 16:14:56] PC HWID: FCC72902D22BEA9E713F1640F9819D67 Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0007456F19801292 Type: [BEST] S/N: 1A94456F Version: 0118.04 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... DO NOT disconnect Box/Dongle ! WAIT 3-4 minutes ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed ---------- Process finished: 2017-01-31 16:15:04 ---------- DongleManager [Infinity-Box] v1.67 [2017-01-31 16:15:04] PC HWID: FCC72902D22BEA9E713F1640F9819D67 Box/Dongle type selected: [BEST] Box/Dongle found: [BEST] Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0007456F19801292 Box/Dongle Serial No (S/N): 1A94456F Firmware version: 0122.02 => Activations: - 03: [BEST] v.0122 - 0A: Test Version |
01-31-2017, 19:26 | #780 (permalink) |
Junior Member Join Date: Jul 2012 Location: BUJUMBURA-BURUNDI
Member: 1786971 Status: Offline Thanks Meter: 0 | I activate my card cm2 but when i update it show this ==== [31/01/2017 09:45:46] ==== Scanning... Box/Dongle found: Main Infinity-Box/Dongle HWID: 00047D3BFF021982 Box/Dongle type selected: Main Infinity-Box/Dongle Box/Dongle found: Main Infinity-Box/Dongle ---------- Process started: 31/01/2017 09:46:01 ---------- DongleManager [Infinity-Box] v1.67 [31/01/2017 09:46:01] PC HWID: 2895CE60D902F0FDBD481EF28AAE5F1D Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00047D3BFF021982 Type: Main Infinity-Box/Dongle S/N: 478C7D3B Version: 0116.02 Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Servicing card - Stage 1... Error servicing card: Server answer:[0036] Smart-Card Keys fault (Smart-Card can not be updated). In most cases it's a Hardware fault or harmful software activity ! One of possible damage reason: Warning ! Your smart-card can be attacked by harmful software ! - GSM-Forum - If you have Activations at your damaged Smart-Card and if you have another Box/Dongle we can try to move Activation to your another Smart-Card. Contact to http://www.infinity-box.com/support/?r=2 for details. Your account will be suspended to avoid permanent Smart-Card damage. |
