Old 05-04-2019, 10:53   #31 (permalink)
Member: 1043909
Thanks Meter: 60,926
Originally Posted by lapasta99 View Post
I have a pity problem with infinity that I can not solve, at the time of opening AST does not open and paarece a leyanda that says connect smarr card and restart software, install their respective drivers and others, the other question is I have to have more activation, that my question may be silly but it is necessary. from now thanks
What is your dongle S/N ?
Old 05-06-2019, 08:27   #32 (permalink)
Member: 2742457
Originally Posted by YellowBoss View Post
Hello,
Fix PC as per instruction for error #57 - https://www.infinity-box.com/support/?r=4
and update dongle firmware after that
Hi sir
I have fixed as the post you sent but update still reported an error
Old 05-07-2019, 05:34   #33 (permalink)
sukhdeep's Avatar
Member: 348478
Thanks Meter: 62
=== DongleManager [Infinity] v1.70 [5/7/2019 9:58:25] ===
Box/Dongle type selected: Infinity-Box/Dongle
Card-Reader: FT SCR2000 0
HWID: 0101938620281292
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): CDEA9386
Firmware version: 0128.02
=== Process started: 5/7/2019 9:58:27 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0006] Your account is temporary suspended.
See problem reason in log file
Contact to http://www.infinity-box.com/support/?r=2
support kindly check how can i activate this card
Old 05-07-2019, 08:13   #34 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by baolua113 View Post
Hi sir
Your card was updated yesterday, I don't see any problem.
Old 05-07-2019, 08:16   #35 (permalink)
Member: 130995
Reading...
As you remember, this card was reported by you as damaged in year 2015, activation was moved from this card you another one ac per your request.
Old 05-07-2019, 11:54   #36 (permalink)
sukhdeep's Avatar
Member: 348478
Thanks Meter: 62
thanks for your support and kind information
Old 05-11-2019, 08:02   #37 (permalink)
Member: 2519178
=== DongleManager [Infinity] v1.70 [11.05.2019 13:54:33] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 1
HWID: 0003CB59FF021982
Reading...
Serial No (S/N): 3CF1CB59
Firmware version: 0137.02
=== Process started: 11.05.2019 13:54:38 ===
Server answer:[0031] Dongle identification data damaged.
=== DongleManager [Infinity] v1.70 [11.05.2019 13:55:33] ===
Searching...
Box/Dongle misconfiguration
Diagnostic code: 54
"UK Edition" status: Off
Last launched Application: 0030 v.0158
=> Activations:
- 00: Infinity-Box/Dongle v.0137
- 02: Language Editor v.0122
- 03: [BEST] v.0122
Diagnostic Key: 7F5E95E60EF35105
У меня такая проблема. обновление прошивки не помогают.
Old 05-11-2019, 11:14   #38 (permalink)
Member: 148515
Thanks Meter: 19,534
Searching...
Reading...
Searching...
Diagnostic code: 54
=> Activations:
- 03: [BEST] v.0122
Hello,
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software.
What to do now:
- Delete fault.bin file from software folder (if you have it there)
- Install latest Infinity software updates
- Run DongleManager
- Update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 05-15-2019, 20:31   #39 (permalink)
Member: 2198565
I do not have any firewall or antivius.
=== DongleManager [Infinity] v1.72 [2019-5-14 2:23:37] ===
Searching...
Card-Reader: Alcor Micro USB Smart Card Reader 0
HWID: 0001089A1FDD4082
Reading...
Serial No (S/N): EF6F089A
Firmware version: 0118.02
=== Process started: 2019-5-14 2:23:40 ===
Server answer:[0005] Authentication failed! Dongle is not Registered yet ?
You should "Register" before you start update !
Click to "Yes" to start Registration process.
If you are already registered click to "No"
Can not connect to server !
Disable Antivirus/Firewall and try again !
The Following User Says Thank You to huiyideguisu For This Useful Post:
Old 05-16-2019, 23:13   #40 (permalink)
Member: 1578034
Thanks Meter: 61
=== DongleManager [Infinity] v1.72 [16/05/2019 23:13:04] ===
Card-Reader: Gemalto e-gate Smart Card 0
HWID: 0003670A00001942
=== Process started: 16/05/2019 23:13:05 ===
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
Old 05-16-2019, 23:24   #41 (permalink)
Member: 1578034
Thanks Meter: 61
after chanche usb port
=== DongleManager [Infinity] v1.72 [16/05/2019 23:23:14] ===
Searching...
HWID: 0000A6FA7F634082
Reading...
Serial No (S/N): E049A6FA
=== Process started: 16/05/2019 23:23:16 ===
The Following User Says Thank You to ip4tnsn0w For This Useful Post:
Old 05-17-2019, 00:35   #42 (permalink)
Member: 1043909
This smart-card is not an Infinity smart-card
Old 05-17-2019, 00:36   #43 (permalink)
Member: 1043909
Searching...
Reading...
Do you have any kind of debug/sniff/trace/crack tools installed at your PC ?
Old 05-17-2019, 00:37   #44 (permalink)
Member: 1043909
Searching...
Reading...
Send an e-mail with problem details to support:
help [at] infinity-box.com
Old 05-17-2019, 20:45   #45 (permalink)
Member: 1578034
Thanks Meter: 61
no only box for workingin my pc
Page generated in 0.27782 seconds with 10 queries
