05-18-2019, 20:34 | #46 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2198565 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.72 [2019-5-14 2:23:37] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0001089A1FDD4082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): E98C335B Firmware version: 0118.02 === Process started: 2019-5-14 2:23:40 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0005] Authentication failed! Dongle is not Registered yet ? You should "Register" before you start update ! Click to "Yes" to start Registration process. If you are already registered click to "No" Can not connect to server ! Disable Antivirus/Firewall and try again ! |
05-18-2019, 22:24 | #47 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, - Run DongleManager - https://www.infinity-box.com/support/?r=5 - Update Dongle firmware now IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
05-18-2019, 22:25 | #48 (permalink) | |
help [at] infinity-box.com | |
05-18-2019, 22:51 | #49 (permalink) | |
Junior Member Join Date: May 2011 Location: Tunisie
Member: 1578034 Status: Offline Thanks Meter: 61 | Quote:
05-20-2019, 12:28 | #50 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2668164 Status: Offline Thanks Meter: 0 | Plase sir solve my problem === DongleManager [Infinity] v1.72 [5/20/2019 4:06:47] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 010280841C6A1292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 08EC8084 Firmware version: 0122.02 === Process started: 5/20/2019 4:06:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to |
05-21-2019, 19:23 | #51 (permalink) | |
To avoid software conflicts in future please do not use "Realterm" at the same time with Infinity software. What to do now: 1. Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR 1. Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: 2. - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
05-24-2019, 11:07 | #52 (permalink) |
Junior Member Join Date: Aug 2005 Age: 46
Member: 171760 Status: Offline Thanks Meter: 4 | === DongleManager [Infinity] v1.72 [24.05.2019 12:16:06] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00032F6300001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): CB452F63 Firmware version: 0136.02 === Process started: 24.05.2019 12:16:09 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to ... |
05-24-2019, 15:02 | #53 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
To avoid software conflicts in future please do not use "snoopy flashtool" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
05-25-2019, 15:57 | #54 (permalink) |
Junior Member Join Date: May 2006 Location: UA
Member: 271257 Status: Offline Thanks Meter: 0 | === DongleManager [Infinity] v1.72 [25.05.2019 17:53:18] === Box/Dongle type selected: [BEST] Card-Reader: Generic EMV Smartcard Reader 0 HWID: 01067E6218571292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 01137E62 Firmware version: 0122.02 === Process started: 25.05.2019 17:53:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. |
05-25-2019, 22:13 | #55 (permalink) | |
To avoid software conflicts in future please do not use "Hexframe" at the same time with Infinity software. What to do now: - Delete fault.bin file from software folder (if you have it there) - Install latest Infinity software updates - Run DongleManager - Update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
05-27-2019, 12:21 | #56 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2086685 Status: Offline Thanks Meter: 1 | === DongleManager [Infinity] v1.72 [5/27/2019 16:19:57] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 00006EDA13114082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 73A76EDA Firmware version: 0137.02 === Process started: 5/27/2019 16:19:58 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 My Infinity Best is working good but CM2 error misconfigure please solve this |
05-27-2019, 12:42 | #57 (permalink) | |
Why do you use debugger and other crack tools with Infinity software ? | |
05-28-2019, 11:46 | #60 (permalink) |
Member: 2086685 Status: Offline Thanks Meter: 1 | Sir, I am also embroidery designer and use wilcom e2 crack. New update e4 is available during update a debugging process accrued. I was flashing qmobile . suddenly a message came from infinity that debugger detect , I stopped everything even e2 and uninstalled. But cm2 stopped format process and mobile dead. After that i searched forum there was a solution to delete fault.bin i deleted this but nothing. This is all things yesterday happened. |
