you should insert card into original Infinity hardware and update it once again now. |
sir i have this problem to update my dongle firmware === DongleManager [Infinity] v1.72 [2020-01-24 09:31:52] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic USB Smart Card Reader 0 HWID: 0000C8B91A224082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 3567C8B9 Firmware version: 0137.02 === Process started: 2020-01-24 09:31:53 === Connecting to server Connection to server failedSocket Error # 10060 Connection timed out. |
how to do please i need help |
Disable your PC firewall and/or antivirus and try again. result ? |
My Dongle Was Working Fine (Infinity Main + CM2 ) Now Show Not Found Code: ==== [1/20/2020 14:50:26] ==== |
Last Known Update Log Is Here Code: ==== [6/14/2018 13:40:24] ==== |
This Smart-Card is not an Infinity Smart-Card - Disconnect all other Boxes and Dongles from PC - Connect ONLY one Infinity Box/Dongle to PC |
hi my best cannt be update === DongleManager [Infinity] v1.72 [01/27/2020 12:38:03] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00075C7019801292 Box/Dongle found: [BEST] Reading... Serial No (S/N): 1B525C70 Firmware version: 0118.04 === Process started: 01/27/2020 12:38:05 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0006] Your account is temporary suspended. See problem reason in log file Contact to http://www.infinity-box.com/support/?r=2 |
2. insert smart-card into your "Alcor Micro USB Smart Card Reader" 3. update dongle firmware now result ? |
help infinity Smart-Card update process may takes up to 4-5 minutes to complete. During update process software may seem hanging but please DO NOT close or terminate forcely application. It may cause harm to your Smart-Card. Just let the process to be finished. - Connect Infinity Box/Dongle (Smart-Card) to PC - Disconnect all other Boxes/Dongles (Smart-Card) from PC - Update Smart-Card Reader drivers to latest version - Disable Antivirus and Firewall - DO NOT interrupt update process even if you think that software is freez ! === DongleManager [Infinity] v1.72 [1/28/2020 16:30:57] === Searching... Card-Reader: FT SCR2000 0 HWID: 0102827B10321292 Select Token Type: instead of Autodetect === DongleManager [Infinity] v1.72 [1/28/2020 16:31:02] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: FT SCR2000 0 HWID: 0102827B10321292 === Process started: 1/28/2020 16:31:02 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
=== DongleManager [Infinity] v1.72 [1/28/2020 17:54:16] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000226E000001942 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 9EF826E0 Firmware version: 0128.02 === Process started: 1/28/2020 17:54:18 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification check error: Applet Authentication Socket Error # 10054 Connection reset by peer. |
=== DongleManager [Infinity] v1.72 [1/28/2020 17:58:47] === Searching... Card-Reader: Generic EMV Smartcard Reader 0 HWID: 000226E000001942 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): 9EF826E0 Firmware version: 0139.02 "UK Edition" status: Off Last launched Application: 0000 v.0000 => Activations: - 00: Infinity-Box/Dongle v.0139 => Box/Dongle misconfiguration. Contact to support ! |
Server answer:[0031] Dongle identification data damaged. === DongleManager [Infinity] v1.72 [1/28/2020 17:50:49] === Searching... Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 0000BED21A224082 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 371CBED2 Firmware version: 0137.02 === Process started: 1/28/2020 17:50:50 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 my fault.bin file is in the link : https://mega.nz/#!vUFnkIBb!XnnHA4gnC...CKs1fxgE8FC0UQ i know exactly what is my fault which is not the infinity team or my hard ware fault "simply i use ida, flexhex ollydbg and many other debuggers but not for cracking ur software aka cm2 or infinity dongle software.. kindly if it is possible fix it for me . 2nd i know that iam out of support even without this issue .. but still trust that you guys wont mind to fix it if it is possible thanks for reading and sorry for bothering . |
*note i cant upload the fault.bin here since the forums just gives err kindly put email address if ur going to ignore my external link . |
