Old 11-28-2019, 21:27   #1 (permalink)
Member: 148515
Thanks Meter: 15,684
Smart-Card/Dongle/Box update problems and solutions
Dear Sirs,
If you have a problem with your Box/Dongle Smart-Card please copy/paste here text given by Infinity DongleManager software.
- Copy/paste ONLY TEXT but not pictures and/or video !
- Do not update your Smart-Card many times to avoid permanent Smart-Card damage !
- If you have Card-Reader Type FT SCR2000 you should use special Card-Reader Drivers - CardReader_Fetian_FT2K.7z
Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202
Download files - https://www.infinity-box.com/support/?r=6
- If you have DITS CCID Smart Card Reader you should use another Card-Reader because this Card-Reader may damage your Smart-Card permanently !
- For today best results gives Alcor Smart-Card Readers.
Previous thread is here - Smart-Card/Dongle/Box update problems and solutions
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post:
Old 12-02-2019, 18:32   #2 (permalink)
Member: 2444197
Sonork: Y
Thanks Meter: 13
aseking for helep
=== DongleManager [Infinity] v1.72 [12/2/2019 23:29:16] ===
Box/Dongle type selected: [BEST]
Card-Reader: Alcor Micro USB Smart Card Reader 1
HWID: 0106765C24881292
Box/Dongle found: [BEST]
Reading...
Serial No (S/N): F4BB765C
Firmware version: 0122.02
=== Process started: 12/2/2019 23:29:17 ===
Connecting to server
Server connection successfully established
Checking DongleManager version...
Your DongleManager is up-to-date
Checking Dongle Identification...
Authenticating on server...
Authentication stage error:
Server answer:[0031] Dongle identification data damaged.
Contact to http://www.infinity-box.com/support/?r=2
Old 12-02-2019, 18:40   #3 (permalink)
Member: 1043909
Thanks Meter: 52,087
Reading...
you must read an instruction Dongle misconfiguration - How to fix and attach fault.bin file.
external file storage services will be ignored. you must attach file here or use e-mail
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 12-25-2019, 08:48   #4 (permalink)
Member: 2536420
Sir please solve my problem
==== [2019-12-24 12:43:21] ====
Smart-Card update process may takes up to 4-5 minutes to complete.
During update process software may seem hanging but please DO NOT close or terminate forcely application.
It may cause harm to your Smart-Card. Just let the process to be finished.
- Connect Infinity Box/Dongle (Smart-Card) to PC
- Disconnect all other Boxes/Dongles (Smart-Card) from PC
- Update Smart-Card Reader drivers to latest version
- Disable Antivirus and Firewall
- DO NOT interrupt update process even if you think that software is freez !
=== DongleManager [Infinity] v1.72 [2019-12-24 12:43:26] ===
Searching...
Card-Reader: FT SCR2000 0
HWID: 0104805924881292
Select Token Type: instead of Autodetect
=== DongleManager [Infinity] v1.72 [2019-12-24 12:43:33] ===
Box/Dongle type selected: Infinity-Box/Dongle
=== Process started: 2019-12-24 12:43:33 ===
Server answer:[0010] Dongle Authentication fail.
Probably last attempt was interrupted or wrong Smart-Card connected.
=== DongleManager [Infinity] v1.72 [2019-12-24 12:43:49] ===
=== Process started: 2019-12-24 12:43:49 ===
==== [2019-12-24 13:24:30] ====
=== DongleManager [Infinity] v1.72 [2019-12-24 13:24:36] ===
Searching...
=== DongleManager [Infinity] v1.72 [2019-12-24 13:24:45] ===
=== Process started: 2019-12-24 13:24:45 ===
==== [2019-12-24 14:41:06] ====
=== DongleManager [Infinity] v1.72 [2019-12-24 14:41:09] ===
Searching...
Box/Dongle is not found
=== DongleManager [Infinity] v1.72 [2019-12-24 14:41:13] ===
Searching...
=== DongleManager [Infinity] v1.72 [2019-12-24 14:41:19] ===
=== Process started: 2019-12-24 14:41:20 ===
==== [2019-12-24 15:42:31] ====
=== DongleManager [Infinity] v1.72 [2019-12-24 15:42:44] ===
Searching...
=== DongleManager [Infinity] v1.72 [2019-12-24 15:42:56] ===
=== Process started: 2019-12-24 15:42:57 ===
Authentication successfull
Service stage 1 confirmed
Securing session...
Session secured ok
Upgrading dongle...
Wait 4-5 minutes ! DO NOT disconnect Box/Dongle !
Last APDU: 133 sec
Card returned error - 0000 at 174/8681
Error upgrading applets:
Disconnected
==== [2019-12-24 17:02:09] ====
=== DongleManager [Infinity] v1.72 [2019-12-24 17:02:12] ===
Searching...
Card-Reader: Generic EMV Smartcard Reader 0
=== DongleManager [Infinity] v1.72 [2019-12-24 17:02:48] ===
Searching...
=== DongleManager [Infinity] v1.72 [2019-12-24 17:03:53] ===
Searching...
=== DongleManager [Infinity] v1.72 [2019-12-24 17:04:44] ===
Searching...
==== [2019-12-25 12:41:49] ====
=== DongleManager [Infinity] v1.72 [2019-12-25 12:42:02] ===
Searching...
=== DongleManager [Infinity] v1.72 [2019-12-25 13:08:54] ===
Searching...
Old 12-25-2019, 09:42   #5 (permalink)
Member: 1867283
infinity cm2 dongle update failed
=== DongleManager [Infinity] v1.72 [12/25/2019 13:09:12] ===
HWID: 0003583D00001942
=== Process started: 12/25/2019 13:09:12 ===
Old 12-25-2019, 12:23   #6 (permalink)
Member: 1867283
Please help me to solve this problem
=== DongleManager [Infinity] v1.72 [12/25/2019 13:27:19] ===
=== Process started: 12/25/2019 13:27:19 ===
Old 12-25-2019, 12:42   #7 (permalink)
Member: 2536420
Arrow My Dongle Update Success
Thank you Sir ..YellowBoss..
my cdma dongle update done
Old 12-25-2019, 14:04   #8 (permalink)
Member: 1043909
Hello,
Install required Card-Reader Drivers:
- File with Drivers: CardReader_Fetian_FT2K.7z
- File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f
OR
Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader)
The next steps are:
- run DongleManager
- update Dongle firmware
IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again !
Old 12-28-2019, 13:43   #9 (permalink)
sajid_rind's Avatar
Member: 1333635
Thanks Meter: 60
My cm2 Dongle after renewal update dongle manager error account is temporary suspended Need help infinity team
=== DongleManager [Infinity] v1.72 [12/28/2019 17:34:31] ===
HWID: 000439CDFF021982
Box/Dongle found: Infinity-Box/Dongle
Reading...
Serial No (S/N): 40A639CD
Firmware version: 0136.02
=== Process started: 12/28/2019 17:34:34 ===
Server answer:[0006] Your account is temporary suspended.
See problem reason in log file
Old 12-29-2019, 01:22   #10 (permalink)
Member: 148515
Reading...
you must insert card back to original Infinity hardware and update it once again now
Old 12-30-2019, 09:07   #11 (permalink)
sajid_rind's Avatar
Member: 1333635
Thanks Meter: 60
Thanks for reply after update with original infinity box than error Smart card is not found
=== DongleManager [Infinity] v1.72 [12/30/2019 12:52:05] ===
Old 12-30-2019, 09:10   #12 (permalink)
sajid_rind's Avatar
Member: 1333635
Thanks Meter: 60
=== DongleManager [Infinity] v1.72 [12/30/2019 12:52:07] ===
Searching...
Card-Reader: Gemalto e-gate Smart Card 0
Old 12-30-2019, 12:07   #13 (permalink)
Member: 148515
Searching...
Try to update it once again now.
result ?
Old 01-02-2020, 14:27   #14 (permalink)
sajid_rind's Avatar
Member: 1333635
Thanks Meter: 60
result ?
thank you so mach infinity team updated done
The Following User Says Thank You to sajid_rind For This Useful Post:
Old 01-05-2020, 00:31   #15 (permalink)
tavoonly's Avatar
Member: 586318
Thanks Meter: 107
=== DongleManager [Infinity] v1.72 [4/1/2020 17:30:41] ===
HWID: 0002D902FF021982
Reading...
Serial No (S/N): 28C4D902
Firmware version: 0134.02
=== Process started: 4/1/2020 17:30:45 ===
The Following User Says Thank You to tavoonly For This Useful Post:
Page generated in 0.25341 seconds with 7 queries
