12-15-2017, 20:57 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SnapDragon 660 - Supported! World first :) Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : C95FD894 ID_BLOCK_L : 7A5A62F8A7746627E2000AFCB76DB1B7 ID_BLOCK_L : 25B6FD808BE1B0FC977F5E7AE44763DC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00000200 UFS SectSize : 0x0200 Boot Ok! Brand : Xiaomi ProdName : jason ProdModel : Mi Note 3 Device : jason AndroidVer: 7.1.1 Manufact. : Xiaomi SysPatch : NMF26X DevComTime: 13.10.2017 13:42:08 QLMxCPU : SDM660 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:22 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : C95FD894 ID_BLOCK_L : 7A5A62F8A7746627E2000AFCB76DB1B7 ID_BLOCK_L : 25B6FD808BE1B0FC977F5E7AE44763DC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00000200 UFS SectSize : 0x0200 --------------UFS Device Info-------------- INFO: {'storage_info': {'total_blocks':244277248, 'block_size':512, 'page_size':512, 'num_physical':4, 'manufacturer_id':21, 'serial_num':3139158637, 'fw_version':'2','mem_type':'eMMC','prod_name':'3V6CMB'}} Boot Ok! Brand : Xiaomi ProdName : jason ProdModel : Mi Note 3 Device : jason AndroidVer: 7.1.1 Manufact. : Xiaomi QLMxCPU : SDM660 DevInfo : SDM660__Xiaomi__Xiaomi__ANDR_v7.1.1__Mi_Note_3__jason__jason Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : storesec.mbn [Read Ok] : ddr.bin [Read Ok] : rpm.mbn [Read Ok] : hyp.mbn [Read Ok] : cmnlib.mbn [Read Ok] : cmnlib64.mbn [Read Ok] : keymaster.mbn [Read Ok] : pmic.bin [Read Ok] : btfm.mbn [Read Ok] : devcfg.mbn [Read Ok] : abl.elf [Read Ok] : misc.img [Read Ok] : fs_gc.img [Read Ok] : xbl.elf [Read Ok] : tz.mbn [Read Ok] : adspso.bin [Read Ok] : lsplash.img [Read Ok] : splash.img [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : NON-HLOS.bin [Read Ok] : cache.img [Read Ok] : cust.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8996 / eMMC Firmware Size : 3653 MiB Done! Elapsed: 00:06:24 Reconnect Power/Cable! Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Xiaomi Device Manufact.: Xiaomi Device Model : jason Device CPU : SDM660 Device IntName : jason Device Version : 7.1.1 CU_SWVer : Xiaomi Device Compile : 13.10.2017 13:42:08 Device ExtInfo : Mi Note 3 Load Ok! Operation : Flash [ v1.17 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : C95FD894 ID_BLOCK_L : 7A5A62F8A7746627E2000AFCB76DB1B7 ID_BLOCK_L : 25B6FD808BE1B0FC977F5E7AE44763DC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00000200 UFS SectSize : 0x0200 --------------UFS Device Info-------------- INFO: {'storage_info': {'total_blocks':244277248, 'block_size':512, 'page_size':512, 'num_physical':4, 'manufacturer_id':21, 'serial_num':3139158637, 'fw_version':'2','mem_type':'eMMC','prod_name':'3V6CMB'}} Boot Ok! Flash Chain : 72 Flashing now Flashing : gpt_main0.bin Flashing : storesec.mbn Flashing : storesec.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : pmic.bin Flashing : pmic.bin Flashing : btfm.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : abl.elf Flashing : abl.elf Flashing : misc.img Flashing : xbl.elf Flashing : xbl.elf Flashing : tz.mbn Flashing : tz.mbn Flashing : adspso.bin Flashing : lsplash.img Flashing : splash.img Flashing : persist.img Flashing : boot.img Flashing : recovery.img Flashing : NON-HLOS.bin Flashing : cache.img Flashing : cust.img Flashing : system.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:06:50 Reconnect Power/Cable! Code: Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Flash [ v1.17 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : C95FD894 ID_BLOCK_L : 7A5A62F8A7746627E2000AFCB76DB1B7 ID_BLOCK_L : 25B6FD808BE1B0FC977F5E7AE44763DC Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00000200 UFS SectSize : 0x0200 --------------UFS Device Info-------------- INFO: {'storage_info': {'total_blocks':244277248, 'block_size':512, 'page_size':512, 'num_physical':4, 'manufacturer_id':21, 'serial_num':3139158637, 'fw_version':'2','mem_type':'eMMC','prod_name':'3V6CMB'}} Boot Ok! Flash Chain : 73 Flashing now Flashing : dummy.img Flashing : storsec.mbn Flashing : storsec.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : pmic.elf Flashing : pmic.elf Flashing : BTFM.bin Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : abl.elf Flashing : abl.elf Flashing : dummy.img Flashing : xbl.elf Flashing : xbl.elf Flashing : tz.mbn Flashing : tz.mbn Flashing : dspso.bin Flashing : logo.img Flashing : boot.img Flashing : recovery.img Flashing : NON-HLOS.bin Flashing : cache.img Flashing : cust.img Flashing : system.img Flashing : userdata.img Flashing : gpt_main0.bin Flashing : gpt_backup0.bin Flash sequence completed! Applying patches for storage # 0 Records : 26 Patch sequence completed! BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:02:59 |
The Following 16 Users Say Thank You to JayDi For This Useful Post: |
12-15-2017, 22:10 | #4 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,103 | No Mr Jaydi medusa pro have release first You Can see date here http://forum.gsmhosting.com/vbb/f475...0-out-2304856/ This loader fonded by me for medusa pro |
12-15-2017, 22:25 | #5 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
Medusa Pro - Xiaomi - for MSM8998, SDM660 | |
12-15-2017, 22:29 | #6 (permalink) | ||
Member: 231728 Status: Offline Thanks Meter: 2,103 | Quote:
Open you aussi Quote:
12-15-2017, 23:00 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Find ANY log from other tool with SD660 report , then I change title and say "sorry". I can add anything in sw, and wrote xxxxx supported! But since no one can test it - that will be just an empty noise. Like with LG M700 Find any sample, connect it to CM2QLM and it will do the magic | |
The Following 12 Users Say Thank You to JayDi For This Useful Post: |
12-15-2017, 23:45 | #8 (permalink) | |
And you have success report and log because you have a phone in hand only And for LG m700 you Can view success report in Octopus LG session all users happy with new solution for frp in edl mode with test point And you Can you add LG M700 loader in cm2qlm ? | |
12-16-2017, 00:43 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | So, fact is fact. M700 loader already inside. As said before - take phone, make TP and do what you need - FRP/Reset/Recover/FW. |
The Following 7 Users Say Thank You to JayDi For This Useful Post: |
12-16-2017, 08:46 | #12 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Quote:
KEEP UP THE GOOD WORK INFINITY | |
The Following 2 Users Say Thank You to nessyb For This Useful Post: |
09-20-2018, 10:30 | #13 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : 36FBABE4 ID_BLOCK_E : 00510000 ID_BLOCK_L : AF7644021BE18AAACE54E418BCDCE40A ID_BLOCK_L : BA3928D06029FCE3AED349A58D3E5C49 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! any tips ? model is R11 pluskt |
The Following User Says Thank You to Mr.3. For This Useful Post: |
09-20-2018, 14:33 | #14 (permalink) | |
Freak Poster Join Date: Nov 2012 Age: 51
Member: 1835756 Status: Offline Thanks Meter: 715 | Quote:
09-21-2018, 18:25 | #15 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Negeri Para Penipu
Member: 142211 Status: Offline Thanks Meter: 90 | not work for PD1723 SnapDragon 660 [MSM8956 Plus] Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : DEA139C2 ID_BLOCK_E : 00730004 ID_BLOCK_L : FA98BBB74193ED5AC0CCBA64EEB10E2B ID_BLOCK_L : B45497B0E02A5AC2B1FE42ECC62AA79E Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Last edited by not2link; 09-21-2018 at 18:34. |
