So V10 phone code not supported ??? I tot Bird V10 phone code, and some other silly Bird phone codes are all supported. To my amasement, Infinity does not support them :confused: :confused: :confused: Pls do something, infinity team. |
Hi, Pls, read flash from your phone and send to: InfinityHelp at yahoo.com.hk V10 Phone code: 1. Power On phone 2. Press "*" once 3. Press side arrow down 3 (three) times 4. Press side arrow up 3 (three) times 5. You will see many interesting things |
2 phones: nothing Quote:
Anything more to try ? |
Used this method on S1180C I was able to reset and phone code was gone. |
bR |
Hi, Pls, read flash from your phone and send to: InfinityHelp at yahoo.com.hk This can helps very much for future development. |
if one were to read flash from fone,what cable to use for bird v10 as s288 cable that comes with infinity box doesn't work on v10. i ve tried using the s288 cable that comes with infinity box but doesnt connect with v10 or s11xx fones. |
Just look into "Documentation" folder with Bird_S1180C_S1120_V09_V10 software. |
i have not been able to unlock one bird since i got this box,do i have to build a cable or wat? |
Check support area "cables/pinouts" section or "Documentation" folder with software. |
I AGREE WITH YOU THERE SHOULD BE MORE SUPPORT FOR THIS FONE |
If you need info how to reset PhoneCode, repair "freez", "restart" problem - please, check support area and you will see how to make this operation. If you have sp-locked V10 and you want to unlock it - just read flash from this phone, send to us and our software will be updated. so, please, give me more info - what is "more support" ? |
