09-23-2009, 10:18 | #1 (permalink) |
Banned Join Date: Jan 2007 Location: India Age: 34
Member: 432364 Status: Offline Thanks Meter: 270 | Sol bold after format failed I have a china sol bold....It was working....Customer given for unlock....I did complete format....Now phone i not switching on....I have eeprom backup but i m not able to write that....Its showing error..... Phone version is TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04 IF any body have this full flash file then plz share Here is log Code: ==== log opened: [9/23/2009 2:19:20 PM] ==== Application: D:\Program files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.72 S/N: 1237:0112 Wait... Device: Autodetect 6205-6227 NOR Done COM14 ready WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [9/23/2009 2:19:34 PM] ==== COM14 [VCP22] selected module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: FA87E900 identification#1 protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN]... file saved: D:\Program files\InfinityBox\ChineseMiracle\micro bold flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000000:0AEA0000000000 Finalization Done Finished, time used: 123 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! ==== log: [9/23/2009 2:22:14 PM] ==== COM14 [VCP22] selected module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: FA87E900 identification#1 protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\id.FA87E900.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71].rpl warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\id.FA87E900._TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71_.rpl warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\backup_security\id.FA87E900.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71].rpl warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\backup_security\id.FA87E900._TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71_.rpl ==================== warning: unknown identification#1 structure: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN - make "Read detailed information" operation - send "system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== detecting security area (code #2)... ................................................................................................................................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .............................. detect standard fat location pass #1... ........................................................ detect extended fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... ........................................................................................................................ ................................................. lock area found Patch required data Done Special operation ... Special operation Done Write ... flash: 98000300000000:0AEA0000000000 flash: 98000300000000:0AEA0000000000 Write: lock-area-1 error: error# 0000FFFF error: flash write error: 00C60000:00002000 error: error# 0000FFFF error: flash write error: 00C60000:00002000 error: error# 0000FFFF error: flash write error: 00C60000:00002000 error: can't write required area Write Fail Finished, time used: 181 sec Remove/Install battery now ! ==== log: [9/23/2009 2:25:35 PM] ==== COM14 [VCP22] selected module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: FA87E900 identification#1 protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\id.FA87E900.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71].rpl warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\id.FA87E900._TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71_.rpl warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\backup_security\id.FA87E900.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71].rpl warning: rpl file not found: D:\Program files\InfinityBox\ChineseMiracle\backup_security\id.FA87E900._TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71_.rpl ==================== warning: unknown identification#1 structure: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN_1B6C7A71 error: Unknown firmware, user action required: 1. download latest software from support area and try again ! 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN - make "Read detailed information" operation - send "system_log_..." file to support: [email protected] - make "Read full flash" operation - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== detecting security area (code #2)... ................................................................................................................................ security area (code #2) is absent detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .............................. detect standard fat location pass #1... ........................................................ detect extended fat location pass #1... ........................................................ fat location can't be detected error: ffs detection failed: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... Patch required data Fail Finished, time used: 93 sec Remove/Install battery now ! ==== log opened: [9/23/2009 2:32:34 PM] ==== Application: D:\Program files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.72 S/N: 1237:0112 Wait... Device: Autodetect 6205-6227 NOR Done COM14 ready Loading file v.02... micro bold loaded ==== log: [9/23/2009 2:33:08 PM] ==== COM14 [VCP24] selected module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: FA87E900 identification#1 protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN]... file saved: D:\Program files\InfinityBox\ChineseMiracle\eeprom[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN]_20090923-143420.B0E.bin flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Eeprom/ffs flash: 98000300000000:0AEA0000000000 Write: Eeprom/ffs error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 68 sec Remove/Install battery now ! Loading file v.02... micro bold loaded ==== log: [9/23/2009 2:35:39 PM] ==== COM14 [VCP24] selected module v2.72 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished device-id: FA87E900 identification#1 protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN]... file saved: D:\Program files\InfinityBox\ChineseMiracle\eeprom[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04.BIN]_20090923-143625.B0E.bin flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting security area (code #2)... security area (code #2) is absent Area: Firmware flash: 98000300000000:0AEA0000000000 Write: Firmware error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished Write Fail Finished, time used: 52 sec Remove/Install battery now ! ==== log opened: [9/23/2009 2:43:25 PM] ==== Application: D:\Program files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.72 S/N: 1237:0112 Wait... Device: Autodetect 6205-6227 NOR Done Thx B.r. |
09-23-2009, 12:06 | #2 (permalink) |
Member: 432364 Status: Offline Thanks Meter: 270 | This eeprom backup before flash http://rapidshare.com/files/28387295..._DUBAI_V04.rar This full flash readed after dead http://rapidshare.com/files/28387451...151423.B0M.rar Plz check B.r. Sunil. |
09-23-2009, 21:44 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! eeprom address for you phone is cotrrect, E00000. do you use any box as interface to phone? |
09-26-2009, 09:25 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, What was the reason to use too old ChineseMiracle software ? Did you tried to flash phone with latest ChineseMiracle software ? |
09-28-2009, 10:47 | #6 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Hert of North KA 25 Age: 42
Member: 115516 Status: Offline Thanks Meter: 113 | Quote:
Hello sir Need to unlock this my hand set hear is log ffs COM16 [VCP1] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4603:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is damaged, recalculation required rom info detection finished device-id: B8296D3C rom info protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98000300000000:0AEA0000000000 Finalization Done Finished, time used: 43 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! hera is sp unlock log COM16 [VCP1] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4603:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:0AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 0A0000EAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEAFEFFFFEA number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is damaged, recalculation required rom info detection finished device-id: B8296D3C rom info protocol ver: 05 ver. sw 1: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04.BIN ver. sw 2: E500.MP.DUBAI.V04, 8E8593E4 ffs offset/size: 00E00000/001F0000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:0AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent detecting ffs/eeprom structure pass 1... .............................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ................................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 startup code area #1 check... warning: rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\id.B8296D3C.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04.BIN_1B6C7A71].rpl warning: rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\id.B8296D3C._TINN O25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI _V04.BIN_1B6C7A71_.rpl warning: rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B8296D3C.[TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04.BIN_1B6C7A71].rpl warning: rpl file not found: E:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B8296D3C._TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S 00.E500_MP_DUBAI_V04.BIN_1B6C7A71_.rpl ==================== warning: unknown rom info structure: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04.BIN_1B6C7A71 error: Unknown firmware detected (v.2.91, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E500_MP_D UBAI_V04__ffs... file saved: E:\Program Files\InfinityBox\ChineseMiracle\TINNO25_08A_GEMIN I_PCB01_GPRS_MT6225_S00.E500_MP_DUBAI_V04__ffs_200 90928-103626.B0E.bin flash: 98000300000000:0AEA0000000000 Backup required data Done Patch required data ... detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Fail Finished, time used: 632 sec Remove/Install battery now ! but set is still locked and restarting i flashed bacup still same hear is full bacup befored opration readed in cpf ans spider http://rapidshare.com/files/28597848..._V01.zipx.html http://rapidshare.com/files/28598818...LCD2.zipx.html thanks | |
10-02-2009, 16:22 | #10 (permalink) |
Member: 432364 Status: Offline Thanks Meter: 270 | I did format with latest version COM14 [VCP1] selected module v2.83 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 504B03043F0000000E00D6663B3B7D47F3EF4EA56E000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000000:50040300000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:50040300000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000000:50040300000000 Finalization Done Finished, time used: 161 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! and also flashed with az cells files but still dead anybody have flash files Thx B.r. |
10-03-2009, 08:30 | #12 (permalink) |
Member: 432364 Status: Offline Thanks Meter: 270 | Phone flashed with your given file Timer: _2009_10_3_12_43_11>> Spider BOX connect with Commport = [14] OK! Timer: _2009_10_3_12_43_11>> BOX_ID=B39BB0BC40470085 BOX_SN=53055Timer: _2009_10_3_12_43_11>> MTK platform selected!Timer: _2009_10_3_12_43_14>> Press ON/OFF key until find cable defines! Timer: _2009_10_3_12_43_14>> Start to search the pinouts defines >>> MTKTimer: _2009_10_3_12_43_16>> Pinouts find Success! Timer: _2009_10_3_12_46_34>> Press ON/OFF key until find cable defines! Timer: _2009_10_3_12_46_34>> Start to search the pinouts defines >>> MTKTimer: _2009_10_3_12_46_36>> Pinouts find Success! Timer: _2009_10_3_12_49_57>> [MTK] Open COM14 success! Timer: _2009_10_3_12_49_57>> Press ON/OFF key please... Timer: _2009_10_3_12_49_58>> Target's hw_ver :0x8A05 Timer: _2009_10_3_12_49_58>> Target's hw_code :0x6225 Timer: _2009_10_3_12_49_58>> Target's sw_ver :0x8A00 Timer: _2009_10_3_12_49_59>> Target's CPU UID :00009F03 Timer: _2009_10_3_12_50_0>> Get correct bootloader for target... Timer: _2009_10_3_12_50_0>> MTK_AllInOne_DA_v3.0848.00.00 Timer: _2009_10_3_12_50_0>> You can relase ON/OFF key! Timer: _2009_10_3_12_50_0>> [DA] loading the 1st bootloader... SuccessTimer: _2009_10_3_12_50_9>> [DA] loading the 2nd bootloader... SuccessTimer: _2009_10_3_12_50_19>> [BROM] start to test UART link... Timer: _2009_10_3_12_50_20>> Waiting the bootloader initilize... Timer: _2009_10_3_12_50_24>> [COM] Success to set baudrate! Timer: _2009_10_3_12_50_24>> [DA] Bootloader running now,OK Timer: _2009_10_3_12_50_24>> Analysis flash file now... Timer: _2009_10_3_12_50_24>> [FLASH] Start to downloading Timer: _2009_10_3_12_50_24>> [INFO] if phone dead after flash Timer: _2009_10_3_12_50_24>> [INFO] Send flash file to [email protected] Please! Timer: _2009_10_3_12_50_24>> Loading spider_SOL_BOLD----LCD2.bin Timer: _2009_10_3_12_53_15>> File Download Successfully Completed!!! Timer: _2009_10_3_12_53_15>> [MTK] Close COM14 success! and also formated with latest chinese micracle software COM14 [VCP2] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9F03:0000 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:50040300000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 504B03043F0000000E00D6663B3B7D47F3EF4EA56E000000 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... . detection phase #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... warning: rom info information not found, possible reasons: .old firmware type w/o rom info data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device rom info finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 flash: 98000300000000:50040300000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:50040300000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98000300000000:50040300000000 Finalization Done Finished, time used: 136 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! but still it is not switching on Thx for trying to help B.r. |
10-03-2009, 09:09 | #13 (permalink) | |
Member: 432364 Status: Offline Thanks Meter: 270 | Quote:
1. Sorry i m using old version of chinese micracle bcoz i m not able to calibrate touchscreen with new version thats why i m using old version 2. How to flash in infinity support area its flash file is not available B.r. | |
10-03-2009, 09:44 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! use similar flash files from support: flashfiles/AT-Telecom/Hi-Messenger/Hi-Messenger_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00 .T500_DUTCH_PR_R0_2_V8_0__En_De_Nl_En_Nl_De.B0M.bi n flashfiles/Nexian/NX-G900/Nexian-NX-G900_XL_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.E 500_MP_R1_0_V20_INDONESIA_En_Id_Exelcomindo.B0M.bi n |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
10-05-2009, 07:23 | #15 (permalink) | |
B.r. | |
china sol bold c ant format | milano | Infinity-Box | 4 | 03-03-2012 15:54 |
Need sol bold flash file | ..::Sunil::.. | CPF-BOX Ⅱ | 3 | 01-24-2011 21:47 |
SOS and Initialization failed on BB Bold after unlocking and inserting Sim Card | BBboldnew17 | BlackBerry (RIM) | 0 | 05-20-2009 18:28 |
