05-07-2019, 15:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Vfd320 firmware reading done but i have an question this f/w flashing will be safe ? Load IDBase v123080 Ok! Operation : Read Firmware [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM3) MODE : BOOTROM PORT : 3 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6580 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 eMMC : OK eMMC : 4500017044453445170A01345DC4EF7E DAInf: 4 : 2 : 156 DA : EXT_RAM NOT initialized! eMMC : OK eMMC : 700100454534454434010A177EEFC45D NAND : DEVICE NOT FOUND NAND : 000000000000000000000000 EMI : DEV : INFINITY EMI : SRC : INFINITY-BOX_INTERNAL_EMIDB_v0 INIT : 0xBC : LP/DDR3 [ 0x00000000 : [ 0 B ] ] DRAM : DRAM: 0x20000000 [ 512.00 MB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 700100454534454434010A177EEFC45D EMMC: VEN : KINGSTON | OEM : 01 | DEV : EE4ED4 EMMC: BOOT1 : 0x00200000 [ 2.00 MB ] BOOT2 : 0x00200000 [ 2.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0xE2000000 [ 3.53 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x20000000 [ 512.00 MB ] CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 23BE949622E9E13B7E888C49230C232D STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : DA USB VCOM Port (COM18) MODE : PRELOADER PORT PORT : 18 Boot done! Patch Level : O11019 Display ID : O11019 release-keys Ver. CodeName : REL Ver. Release : 8.1.0 Sec. Patch : 2018-05-05 Build Time : 1527929609 Product Model : VFD320 Product Brand : Vodafone Product Name : Smart_C9 Product Device : VFD320 Board Platform : mt6580 Product Manfct : Vodafone Product Info : k80hd_bsp_fwv_512m Product Board : MT6580M Board Platform : mt6580 MT6580__Vodafone__VFD320__8.1.0__O11019__k80hd_bsp _fwv_512m SecureDevice : Paired type! -> INFO : That device WILL dead after ReadOut Flashing! -> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available! -> INFO : In most cases you can "unsecure" device in Engineer mode Read : preloader.bin Read : proinfo.img Read : nvram.bin Read : persist.img ExtSparse : Compression ratio : 100% Read : lk.bin Read : boot.img Read : recovery.img Read : logo.bin Read : odmdtbo.img Read : vendor.img ExtSparse : Compression ratio : 70% Read : tz.img Read : secro.img Read : system.img ExtSparse : Compression ratio : 18% Read : cache.img Read : userdata.img FW Size : 1.13 GB Android Info saved : _Android_info.txt Scatter : MT6580_Android_scatter.txt Saved to : C:\Users\XYZ\MT6580__Vodafone__VFD320__8.1.0__O110 19__k80hd_bsp_fwv_512m\ Done! Elapsed: 00:07:16 |
06-03-2019, 16:08 | #4 (permalink) |
Junior Member Join Date: Jan 2019 Location: Europe
Member: 2886795 Status: Offline Thanks Meter: 0 | "SecureDevice : Paired type! -> INFO : That device WILL dead after ReadOut Flashing! -> INFO : Only partial flashing ( f.e. SYSTEM, VENDOR and etc. ) available! -> INFO : In most cases you can "unsecure" device in Engineer mode" I would also like to understand what this means too. |
