04-14-2008, 01:09 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: zunZun Team Age: 43
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,674 | Solution to problem flashing Pantech PG1410 with PNModule_v1.08 And there is no problem of the battery, because the burden with an external source 100% full Here is the log: -------------------------- [Infinity Box] v1.08 S/N: 07**:**** Wait... Current device: Pantech PG-1410 Loading file v.02... PG1410C_HLMC0111082005_v10.8FM.bin loaded Testing COM2 at 921600... COM2 [VCP0] selected Device: Pantech PG-1410 Checking data, wait... Action: flash write Write: Firmware Skip: File system Skip: Language pack Skip: Eeprom "smart write" enabled Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200:0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware flash: 01227E22212200:0CE59F00000000 error: error# 000000FF error: flash write error: 01000000:00010000 Write Fail Finished, time used: 14 sec Remove/Install battery now ! ------------------------------------------------------- Flashing 10000% Pantech PG1410 Oks with InfinityUpdate_PNModule_v1.03.exe and PG1410 100% unlocked Here is log: ------------------------------------------------------- Testing COM2 at 921600... COM2 selected Device: Pantech PG-1410 Checking data, wait... Action: flash write Write: Firmware Skip: File system Skip: Language pack Skip: Eeprom Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200 flash: 0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 0000527A Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware flash: 01227E22212200 flash: 0CE59F00000000 flash: 01227E22212200 flash: B0800400000000 Write Done Finished, time used: 324 sec Remove/Install battery now ! ------------------------------------------------------------ Waiting for the solution Infinity-Team. The best Team from support. BR elcapitel. |
04-28-2008, 22:51 | #2 (permalink) |
Member: 166270 Status: Offline Sonork: 100.1579747 Thanks Meter: 12,674 | Another test for unlock 100% ok the Pantech PG1410 from Telcel Mexico. Another test for unlock 100% ok the Pantech PG1410 from Telcel Mexico. Flashing the phone with the flash PG1410C_HLMC0111082005_v10.8FM.bin from support, and them unlock with cable in "DATA" mode. Another detail, flash with PNModule_v1.03 , because PNModule_v1.08 no working for flashing this model Here the log of the operation -------------------------------------------------------------- Testing COM7 at 921600... COM7 selected Device: Pantech PG-1410 Checking data, wait... Action: flash write "smart write" enabled Write: Firmware Skip: File system Skip: Language pack Skip: Eeprom Boot... Phone must be POWERED-OFF ! Cable must be in "GPRS" mode ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E22212200 flash: 0CE59F00000000 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb id: 00005272 Boot Done Set baud... 921600 Set baud Done Check flash... Check flash Done Check space... Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write: Firmware flash: 01227E22212200 flash: 0CE59F00000000 flash: 01227E22212200 flash: B0800400000000 Write Done Finished, time used: 311 sec Remove/Install battery now ! Action: unlock COM7 selected Phone must be POWERED-ON ! Cable must be in "DATA" mode ! Connecting, wait... Phone connected. Working... file saved: backup_sp-unlock_log_20080428-152907.8FX.bin active lock(s) found, working... Finished, time used: 6 sec Power-off phone by "Power" button (don't remove battery). -------------------------------------------------------- Infinity-Help please corrig this bug. elcapitel BR. |
Problem flashing Pantech PG6200 [ANSWERED] | zeppelin79 | PolarBox 3 | 4 | 07-02-2010 14:01 |
Strange Problem with Blackberry 8700c when i try to re-flash after unlocking with MML | Boshko_Alfa | BlackBerry (RIM) | 0 | 04-01-2009 10:57 |
Solution To Problem After Dead Set With Bb5box !!!! | Burnt Cobba | BB5BOX | 14 | 09-26-2007 11:23 |
Solution to problem with HWK (unlocking) | Bi0H4z4rD | HWK | 7 | 08-10-2005 12:04 |
