11-18-2008, 14:16 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Solution-->Some mobile not powering on Infinity pinoutfinder Some mobiles not powering up on infinity pinout finder for example if you wana reset user code , cal. screen formatffs in safe mode , changing imei etc mobile must power on for these type of opretion and for useing infinity pinout finder you must connect power from pinfinder so some mobile can't power on properly and those opretion not done so see that pic and do what i did exactly .... try and post results @ infinity if you think that this solution is GOOD then Please make it SLICKLY ON request of mine @ Users if you got any problem Please ask here i will try to do my BEST to solve your problems about this Br Faisal_Computer |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
11-19-2008, 08:49 | #3 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Pakistan
Member: 570093 Status: Offline Thanks Meter: 1,067 | i also use power supply with pinfinder.but method is diffrent fron faisal bhayee.i connect power supply direct to phone -,+ then the connect other negative - wire on power supply to negative - wire of pinfinder box and this work ok for me. |
11-19-2008, 08:59 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | yes already tested if u have problem in finding pinout u need to select 2.8V and after find pinout change 2.8v to 4.5V BR MapleGsm(Umer) |
6030 mobile not power on, on battery and working fine on power supply | kashif_khatri | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 09-19-2009 02:57 |
k530i red 52 .full flash ok. but mobil not power on | top50gsm | SETool2 | 5 | 05-21-2009 19:12 |
can not power on by infinity pinfinder | surayya | Infinity-Box | 2 | 04-15-2008 20:31 |
Mobiles is not Powering On | imran_qasim | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-22-2005 15:32 |
t100 not power on after flash, not power on when original cable is plug | GYZMO | VLSI, Conexant, Skyworks and Old Models | 8 | 01-07-2004 00:34 |
