09-08-2006, 02:39 | #1 (permalink) |
Major Poster Join Date: Mar 2005 Age: 49
Member: 124680 Status: Offline Thanks Meter: 2 | Solution to unlock C168 Device: C168 Checking data, wait... Action: Unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 1120-000 HW ver: TCT-5- Check Flash Done Check Parameters... file saved: Backup_unlock_2006-9-7_23-52-29.69F.bin Err: unknown or damaged device. read flash and send to support Check Parameters Fail Finished Remove/Install battery now ! Time used: 22 sec Make "SP-Unlock" operation now ! This is the message I recieved when unlocking Motorola C168 phone and the phone can't come on now so please help me attached to this is the flash file I read from the dead phone |
09-08-2006, 06:50 | #2 (permalink) | |
Use latst Moto02 module v1.19 from support area to unlock this phone (firmware 1.120 supported). C168 can't be killed during unlock, especially when software just check unlock possibility and terminate operation before make any changes in phone memory (it's your case), so just check battery (charge it) and try to press and hold phone power buttom for some time and for sure your phone can power-on. | |
05-16-2007, 22:51 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! all your questions is answered in our Shell module. run it, pick model C168- you will see which cable to use and also needed program will open automaticly. all what you need- to pick right com port to work with. then go to service tab and push "unlock" |
any free solutio, to unlock c168? | jawad8305 | Motorola ODM | 2 | 04-15-2008 10:42 |
how to unlock c168 | qayyoom1 | Smart-Clip | 2 | 04-15-2007 12:46 |
Failed to unlock C168 with SmartMoto 2.19 ? | ales6orah | Smart-Clip | 12 | 02-24-2007 21:30 |
is it possible to unlock c168 and w220 ? | harish35200 | Smart-Clip | 3 | 02-02-2007 07:11 |
How to unlock Z150 Movistar - Spain? There are any solution to unlock this new model? | Grupo MovilFree | QUALCOMM Models (3G) | 7 | 09-22-2006 16:35 |
