11-28-2008, 16:10 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, "Pinouts" update v1.33 just uploaded in support area. Please, download and install it. Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
04-09-2009, 13:21 | #3 (permalink) |
Crazy Poster Join Date: Jul 2006
Member: 305319 Status: Offline Thanks Meter: 5 | sir plz help me t161l flash problame module v1.60 Device: Huawei-T161L Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 20FA:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... backup critical area Done Check memory ... Check memory Done Write ... reset... error: set erase range error: reset failed Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, time used: 119 sec Remove/Install battery now ! |
04-09-2009, 13:22 | #4 (permalink) |
Member: 305319 Status: Offline Thanks Meter: 5 | masood sir plz help me t161l flash problame module v1.60 Device: Huawei-T161L Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 20FA:8000 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... backup critical area Done Check memory ... Check memory Done Write ... reset... error: set erase range error: reset failed Erasing: Firmware error: set erase range error: erase failed: 00400000 Write Failed Finished, time used: 119 sec Remove/Install battery now ! |
07-09-2009, 07:18 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Afghanistan 0093786144898 Age: 37
Member: 938983 Status: Offline Sonork: 100.1585802 Thanks Meter: 102 | I HAVE A ZTE A35 WHEN FLASHING SHOWS error: erase failed: 00400000 Write Failed Finished, time used: 37 sec Remove/Install battery now ! I NEED URGENT HELP PLEASE |
07-09-2009, 08:56 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: U A E
Member: 50511 Status: Offline Sonork: 100.109684 Thanks Meter: 307 | connector_usb_mini-5.gif === flash/unlock cable === keyboard top _____ /12345\ _______ 1: Gnd 3: box Rx/phone Tx (RJ45 pin-3) 4: box Tx/phone Rx (RJ45 pin-2) === USB cable === use ordinary Moto C350 usb cable |
UNLOCK ALL MODEL Huawei T158B,Huawei T156B,Huawei T161L,Huawei,KENYANS CONTACT ME NOW | hassanjinja1 | Main Sales Section | 0 | 10-22-2009 13:45 |
Huawei-T161L unlock suss | tanha | Infinity-Box | 1 | 01-06-2009 19:02 |
test reports huawei t161L and konka c625 | gsmbac | Infinity-Box | 1 | 12-30-2008 17:55 |
Re-lock huawei t161l | bluffmaster | Infinity-Box | 1 | 11-28-2008 16:29 |
huawei t161L succesfully unlocked | gsmbac | Infinity-Box | 2 | 11-24-2008 16:48 |
