Old 02-24-2010, 19:02   #1 (permalink)
kimo59's Avatar
Member: 183437
some info on ZTE g-N281 / SFR 343 !
cable LG GW300 rj45
COM4 [VCP4] selected
module v3.17
Device: ZTE-N281
Checking data, wait...
Action: read firmware NAND
interface: BROM_DLL_v3.936.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0004]: 00EC:0076005A003F [SAMSUNG] K9K1208X0C
chip size: 64Mb
page/spare size: 0200/0010
pages/block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (921600)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/01C00000
firmware size: 32Mb
ffs size: 28Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: ORANGE_OFR_FR_P107A3V1.0.4B05
detect NAND info...
number of areas to read: 1
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
nfi area detection...
bootloader version: ZTENJ35_OG_09A_BOOTLOADER_V005_MT6235B_ORANGE_ENG_ EN_P107A3V1_0_
nfi area detection finished: Ok
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_OFR_F R_P107A3V1_0_4B05.BIN
project-id: ORANGE_OFR_FR_P107A3V1.0.4B05, 00000000
code offset: 00000000
ffs offset/size [01]: 02000000/01C00000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
New firmware detected (v.3.17, database date: 16.02.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: support@infinity-box.biz or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
area size: 32Mb
file saved: C:\Documents and Settings\Admin\Bureau\ZTE-N281_ZTENJ35_OG_09A_PCB01_GPRS_MT6235B_S01.ORANGE_ OFR_FR_P107A3V1_0_4B05__firmware_20100224-163140.B4X.bin
Disconnect...
done
Finished, time used: 13 min 2 sec
Remove/Install battery now !
http://rapidshare.com/files/35530262...0224-1631.html
The Following 3 Users Say Thank You to kimo59 For This Useful Post:
Old 02-25-2010, 15:59   #2 (permalink)
kimo59's Avatar
Member: 183437
direct unlock with "smart fast" method not work,
phone detected but can t go on test-mode : Connecting at 19200, wait ...
phone freeze at logo
others methods "standart" etc... not supported
Old 02-25-2010, 16:06   #3 (permalink)
YellowBoss's Avatar
Member: 1043909
Hi,
Just use other cable (test points under battery) and phone will be unlocked with "smart fast" method for sure.
Cable: C:\Program Files\InfinityBox\pinout\ZTE-G-R231.jpg
Old 02-25-2010, 18:23   #4 (permalink)
kimo59's Avatar
Member: 183437
Ok thx i understand, so not possible by rj45 ???
smart unlock without need to solder wires
i remember at start zte x760 was unlocked by solderind rx,tx,gnd after this rj45 cable worked like a charm (easy unlocking and proper)
Best Regards
The Following User Says Thank You to kimo59 For This Useful Post:
Old 02-25-2010, 18:32   #5 (permalink)
YellowBoss's Avatar
Member: 1043909
Best Regards
Hi,
We have to make more tests with bottom connector, can not tell you anything right now.
Old 02-26-2010, 19:21   #6 (permalink)
kimo59's Avatar
Member: 183437
rj45 connector
==== [26/02/2010 19:51:31] ====
COM4 [VCP1] selected
module v3.19
Action: "sp-unlock"
unlock method: smart fast
Model: ZTE-N281
19200 autodetect
Initializing [6235:8A04:8A01]...
CPU: MT6235
chip: 0000:0000:0003
status: FF
rom: 4D573031
Connecting at 19200, wait...
error: can not finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 43 sec
rj45 WIRED
==== [26/02/2010 19:48:18] ====
module v3.19
Action: "sp-unlock"
Model: ZTE-N281
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Phone detected, wait...
Hardware: MT6235,E04
Date: 2000.00.00
Version: 1.0
Version: ORANGE_OFR_FR_P107A3V1.0.4B05
Version: 09AZTENJ35_OG_09A
83 byte(s) read
imei: 35769203003952
connection Ok
189 byte(s) read
reading data...
building new data...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 18 sec
The Following 2 Users Say Thank You to kimo59 For This Useful Post:
Old 03-07-2010, 16:10   #7 (permalink)
Member: 113924
Hi,
Unlock success
COM10 [VCP0] selected
module v3.23
Action: "sp-unlock"
Model: ZTE-N281
19200 autodetect
CPU: MT6235
status: FF
rom: 4D573031
Date: 2000.00.00
Version: 1.0
83 byte(s) read
imei: 35769203012623
connection Ok
189 byte(s) read
reading data...
reading data #2...
writing data...
177 byte(s) read
reading data...
972 byte(s) read
writing data...
verifying...
verification Ok
done
Finished, time used: 34 sec
Thanks Infinity team
The Following 3 Users Say Thank You to Akili Bulent For This Useful Post:
Old 03-08-2010, 13:18   #8 (permalink)
Member: 724489
pinout for zte-g n281
Old 03-08-2010, 17:52   #9 (permalink)
Member: 113924
Here's the pinout for this model
The Following 4 Users Say Thank You to Akili Bulent For This Useful Post:
Old 03-08-2010, 17:56   #10 (permalink)
YellowBoss's Avatar
Member: 1043909
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update: Infinity-Box
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
FAQ: Frequently Asked Questions, cables/pinouts, supported models - GSM-Forum
Old 03-20-2010, 14:57   #11 (permalink)
javakiller's Avatar
Member: 180873
Originally Posted by YellowBoss View Post
Hi,
You are wrong, this is for N231 which is different from N281, see below for correct testpoint
A bit easier to understand testpoints
Tested by me on several phones
The Following 2 Users Say Thank You to javakiller For This Useful Post:
Old 03-20-2010, 17:02   #12 (permalink)
InfinitySupport's Avatar
Member: 130995
@javakiller
What is the difference in your and mine pictures ?
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post:
Old 03-22-2010, 13:01   #13 (permalink)
Member: 145018
thanks men is goot testpoint
The Following User Says Thank You to shaaban For This Useful Post:
Old 03-30-2010, 21:44   #14 (permalink)
K1n
Member: 237887
please help me when i try to unlock my ZTE-G N281 I get this error. i try to do it with modifying rj45 cable it's my first ime maybe it's bad connexion. tell me if i must use battery
COM1 [VCP0] selected
module v3.29
Action: "sp-unlock"
Model: ZTE-N281
error: boot initialization step #2 failed: EC
19200 autodetect
error: boot phase #2/1 failed
Can not initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. ffs/eeprom is serious damaged, use repair ffs/eeprom files or use other unlock/format method
Finished, time used: 7 sec
Old 03-31-2010, 13:10   #15 (permalink)
YellowBoss's Avatar
Member: 1043909
module v3.29
Action: "sp-unlock"
Model: ZTE-N281
19200 autodetect
Possible reasons:
Hello,
It's for sure cable problem (wrong pinout).
If you use just an RJ45 cable you have to use Rx/Tx/Gnd wires and battery should be installed.
If you use PinFinder you do not need to connect battery but "power" wires shhould be connected instead of battery.
some info on MyWay touch ! kimo59 Infinity-Box 24 10-11-2011 11:14
some info on GHT G3 ! kimo59 Infinity-Box 10 07-16-2011 09:41
Need Some Info on MYC-2 Newbee Longly600 ARM9 BASED M62 / M62+ 0 03-14-2005 16:47
SOME INFO ON DEJAN HEX GSMWIZARD Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 12 02-12-2002 22:25
Page generated in 0.40680 seconds with 12 queries
