some j120i can,t be unlocked hi sir am trying to unlock smoe j120i i have done 10 pieces but now with some pieces getting error and after this error when i put sim inside the phone it show phone not authorized . any help ll be apriciated. thx |
If you want to get help you must explain the problem so detailed as possible and include Log. Also you can try to press "Repair" button in software. |
ok sir here is log COM3 selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 100C-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071031-120153.6AE.bin Check parameters Done Check data... Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 11 sec Remove/Install battery now ! |
ok sir here is log plz tell mi what to do COM3 selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 100C-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071031-120153.6AE.bin Check parameters Done Check data... Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 11 sec Remove/Install battery now ! |
Probably eeprom damaged or something like this. Just use "Repair" button and everything should be Ok. |
ok sir i tryied to repair but its same after repairing. so where is problem sir . help plz. thx |
hello! please post a log of "repair" operation |
if "repair" not work you must write "repair eeprom" file and then make "repair" procedure again and phone will be 100% Ok. I have made several pcs by myself ! |
