10-29-2007, 14:18 | #1 (permalink) |
No Life Poster Join Date: May 2006
Member: 275861 Status: Offline Sonork: 100.111 Thanks Meter: 166 | some j120i can,t be unlocked |
10-29-2007, 15:18 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | If you want to get help you must explain the problem so detailed as possible and include Log. Also you can try to press "Repair" button in software. |
10-31-2007, 12:08 | #3 (permalink) |
Member: 275861 Status: Offline Sonork: 100.111 Thanks Meter: 166 | ok sir here is log COM3 selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 100C-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071031-120153.6AE.bin Check parameters Done Check data... Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 11 sec Remove/Install battery now ! |
10-31-2007, 12:10 | #4 (permalink) |
Member: 275861 Status: Offline Sonork: 100.111 Thanks Meter: 166 | ok sir here is log plz tell mi what to do COM3 selected Device: Sony-Ericsson J120i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 208814FFFFFFFF:20881400000000 flash: ST Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 100C-000 version sw: MLD-5- Check flash Done Check parameters... reading Sony-Ericsson J120i_eeprom_calibration-1... file saved: backup_Sony-Ericsson J120i_eeprom_calibration-1_20071031-120153.6AE.bin Check parameters Done Check data... Check data Done Writing... error: no locks present or unknown eeprom structure Writing Fail Finished, time used: 11 sec Remove/Install battery now ! |
new zong with tourch can,t be unlock | pakmobiles | FuriousGold | 3 | 03-29-2010 16:26 |
★★Post here all unlocked HTC PHONES that can NOT be unlocked via HTC FACTORY CODES★★ | BaNgErS | PolarBox 3 | 0 | 01-13-2010 21:58 |
some one can help me unlock blackbeery locked with verizon canda | motaz alrnuti | BlackBerry (RIM) | 3 | 09-05-2009 14:45 |
some one can help me unlock blackbeery locked with verizon canda | motaz alrnuti | Various | 2 | 09-03-2009 22:06 |
some one can help me unlock Blackbeery locked with Verizon canda | motaz alrnuti | Various | 2 | 09-03-2009 00:17 |
