12-18-2010, 12:18 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | some nokia chinese unknown model can't calibrate touch screen COM3 [VCP0] selected module v3.25 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... HEXING26_08B_GEMINI_PCB01_GPRS_MT6226_S01.B024-1C_L26_V202__fullflash_20101208-184248.B0M.bin loaded ffs/eeprom record offset detected ffs/eeprom record size detected ffs/eeprom record offset detected ffs/eeprom record size detected Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031E72:FB0F status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware 80 byte(s) read warning: wrong packet cs connection lost error: operation failed ! Finished, time used: 6 sec Remove/Install battery now ! the full flash http://rapidshare.com/files/43581126...184248.B0M.bin |
12-19-2010, 22:50 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! full flash read from working phone will solve this problem also. but if Touchscreen itself is not working- you still will not be able to use this phone, if it does not have hardware keys |
12-26-2010, 10:46 | #6 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
InfinityHelp means all normal keys (1,2,3,4,..., call, end, etc.). since some phone has only touch screens and in that case if touch calibration is not bypassed you cannot use the handset. Try to read full flash from a working phone and then write flash to this phone. Wr. | |
12-26-2010, 21:01 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! yes, mr PASSIONATE_BOYS is correct. main idea of "touchscreen calibration" is to make phone work even if screen is damaged. But this is only possible when phone has normal keys "1", "2" etc |
12-27-2010, 19:23 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if you can not enter to test mode with any methods and therefore can not do touchscreen calibration bypass- you can do this by reading FULL flash file from working phone and writing to this, damaged one |
