09-21-2011, 14:47 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DEATH VALLEY
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | Ot-306 restart after unlock module v4.01 Device: Alcatel-306X, 306A Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A08]... CPU: MT6223 high speed boot On chip: 0011:840B:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 115200 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: c:\InfinityBox\MModule\backup_security\id.075E9F53 .[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_0888B855].rpl ==================== New firmware found (v.4.01, database date: 19.08.2011): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 075E9F53 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 55B88808 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 961 provider: 306X-2AVDKE3 customization: CI96CA00 customization: XI96CA00 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CI96CA00 customization name adjusted customization: CI96CA00 customization name adjusted customization detected: CI96CA00 customization: CI96CA00 customization: XI96CA00 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->086403C0 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 file saved: c:\InfinityBox\MModule\backup_security\Alcatel-306X,306A__system_log_075E9F53_0888B855_20110921-162545.B0X.bin Finished, time used: 2 min 23 sec Remove/Install battery now ! |
The Following User Says Thank You to KYEJUSA For This Useful Post: |
09-22-2011, 09:11 | #2 (permalink) |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | Please anyone upload ot-306 free file on infinity support,because i flashed with a file from support but its still locked, the file is from comcel,thanks. |
09-22-2011, 18:00 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Hello, Please, try this: For newest Alcatel models (f.e. 203, 708, V541 etc.) that freez/reboot after sp-unlock: 1. use "MModule" software v3.22 or newer 2. use "Write" button from software "Service" page and write original imei (from phone back label) 3. make "sp-unlock" |
09-23-2011, 12:15 | #4 (permalink) | |
Member: 394869 Status: Offline Sonork: TAKE NO CHANCES Thanks Meter: 500 | Quote:
09-23-2011, 12:41 | #5 (permalink) | |
Insane Poster Join Date: Sep 2005 Location: Uzbekistan Age: 39
Member: 177238 Status: Offline Thanks Meter: 11 | Quote:
09-26-2011, 12:02 | #7 (permalink) | |
Loading file v.02... error: data error ! Loading failed, probably damaged data file how to write it back? | |
01-09-2012, 13:37 | #12 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | Use this file Alcatel-306X,306A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__fullflash_part_1_of_1_20120109-141906.B0M.bin It is readed from one OT-306x from Wind Italy NOT locked. Or try to use OT-305 file, I think is almost the same phone http://www.gsmarena.com/compare.php3...&idPhone2=3187 |
09-10-2012, 13:59 | #13 (permalink) |
Freak Poster Join Date: Sep 2003 Age: 46
Member: 39460 Status: Offline Thanks Meter: 17 | hello im in same situation , i full flash with the mediafire flash , now the phone is on but the screen is totaly white !!! any other full flash maybe the lcd is not compatible with this version , the phone is from ( la poste ) france please help with full flash |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
