04-13-2015, 16:06 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Some Test Report With {1.17} (6261) Cpu All Inside :) Singel Click No Need Format No Any Kind's Of No Service Problem , After Format Because No Need Format Read Phone Lock Read Privacy Lock Read Mobile Tracker (Anti-theft) Grate Code: Chinese Miracle II [MTK module] v 1.17 Operation : Read UserCode [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 2A38B80B6A1F9702ABC4F9B12D664762 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 55881122 MobileTracker : 87654321 , Privacy Lock : 12345678 Done! Elapsed: 00:00:07 Reconnect Power/Cable! Code: Operation : Read UserCode [ v1.17 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 8 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0000 BB_CPU_SN : 2A38B80B6A1F9702ABC4F9B12D664762 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x0112 , [0] : FLASH_DIE : 00C2 0020 0016 0000 [0] : FLASH_LEN : 0x00400000 SDS : 0x003FE000 , 0x00002000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 25252525 MobileTracker : 96969633 , Privacy Lock : 08080852 Done! Elapsed: 00:00:06 Reconnect Power/Cable! Wow Really Really Hard Work |
The Following 3 Users Say Thank You to pradeep_kus For This Useful Post: |
04-13-2015, 16:18 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thanks a lot for test report ! Here is official information about 1.17 update: http://forum.gsmhosting.com/vbb/f296...tures-1937687/ |
