08-13-2009, 17:14 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Pakistan Age: 39
Member: 693282 Status: Offline Sonork: 100.1602586 Thanks Meter: 41 | pinfinder cannot find pinouts thanks Moon |
08-13-2009, 18:54 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
read manual carefully and check if still problem than post again with exact details what u tried and what was the result | |
08-13-2009, 23:13 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all check if phne is MT62xx mcu based. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy Chinese Miracle select MT62xx MCU in pinfinder, select cable type. press Power button. Red led will indicate that power is activated. Try to power On phone. If it does power On- set "activation tries 20" and push "find pinout" keep power button pressed all the time while pinot is searched. |
08-27-2009, 14:57 | #7 (permalink) |
Insane Poster Join Date: May 2009
Member: 1024853 Status: Offline Thanks Meter: 24 | Hello i Purchased a New Infinity box with PinFinder PinFinder is Detected. but PinFinder Not Detect any CHina Mobile RX TX i m 100% sure about my procedure are RIght.becouse i have to check these mobiles another infinity+PinFinder from my neighbour shop keeper. ok please Help Me What can i do with my pinfinder? |
08-27-2009, 20:44 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
do you able to power On searched phones using pinfinder power? in other words: when phone is sourced from box power- do you able to power it On? this is main condition for success pinout search. If not- you need to modify your main infinity box and shortcut diode. Procedure is described in pinfinder user manual, trubleshoting section | |
08-28-2009, 07:03 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: tampin malaysia Age: 61
Member: 117956 Status: Offline Thanks Meter: 115 | Already modified shortcut diode , but many model phone pinout still cant be find by pinfinder ! This is disadvantage of infinity box , compare to other tool . Please update pinfinder !!! |
08-28-2009, 18:15 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! there is nothing about box. I do all own phones by pinfinder. and i can confirm: If pinfinder can not find pinout- this means only one: pinout is located as test points on PCB. if phone can be powered On from box power and "finder activation tries" is set to maximum, but pinout still can not be found- search for test points |
08-29-2009, 23:45 | #11 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Colombia
Member: 193303 Status: Offline Sonork: 100.1613585 Thanks Meter: 104 | i have same problem. software version: 1.19 cable type: 2x5 (L10C) platform: MT: MT62xx (autodetect) searching adapter at COM6... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 20 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed 19200 fixed failed to detect pins time required: 81 sec Trying to Power-On... Power On ! Set parameter to value 20 (or more) and repeat operation (parameter "Finder activation tries") |
08-30-2009, 20:34 | #12 (permalink) | |
lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is mt62xx family | |
08-31-2009, 14:40 | #13 (permalink) |
Member: 193303 Status: Offline Sonork: 100.1613585 Thanks Meter: 104 | Is MT62xx i can't conect any phone. the pinfinders is neww but is damage and i need unlink my infinity with this box for buy other pinfinder. |
08-31-2009, 16:06 | #15 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | are using cell phone battery so the error, plug in this cable --> http://cellcarcol.forumcommunity.net...tpost#lastpost |
my pinfinder cannot find tx,rx | sharif_tell | Infinity-Box | 4 | 01-19-2009 20:50 |
Cannot find PinOut Second CPU | DualSimCell | SpiderMan | 0 | 09-30-2008 04:49 |
PinFinder can't find pinout for HUAYU HY628 | loshh | Infinity-Box | 1 | 08-07-2008 16:02 |
